Like Tree22Likes
Old 04-21-2014, 12:17 PM
  #15751
Originally Posted by nitro-rob
Not a Team C fan but I get my ass handed to me by a pair of those every week. The drivers are good but they seemed to get better when they moved to that centre motor design car.
So a 2wd Team C car beats you with your DEX410 ? You better start training more
ridgeracer is offline
Old 04-21-2014, 12:33 PM
  #15752
My front center drive shaft keeps popping out. It appears that I have too much chassis flex. Anyway to fix this?
MugenMan99 is offline
Old 04-21-2014, 12:37 PM
  #15753
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Originally Posted by 13Maschine
Finally had a chance to run the new 2 way slipper at SCVRC. Have to say I love it. Very easy to adjust and it seemed to have a nice operating range. I started off tight to make sure I didn't blow it up with my new 5.0 motor and as the night went on I would loosen it up just a touch. it really made the car easier to drive. Less of the bounce you get on tough jumps and I felt like I could get on the throttle much sooner.
All that being said I wonder if durango will adopt a center diff for the V5 car? Maybe they will just call it the Bman410?
That would be awesome! But I'd let them call it what they want if they allow me 5% of the sales....
Bman's 3XNT is offline
Old 04-21-2014, 01:05 PM
  #15754
13Maschine's Avatar
hahahahaha, I hear ya brotha!
Forgive me durango fans but I've been looking at the D413. I like some of the elements specifically the shock tower and mount design with lots of extra bracing. It also sounds like my local shop is going to ditch durango and carry hot bodies parts. I do think it's a little too phat though. That's what I dig about my 410. It's very narrow.
BMan it doesn't seem possible to fit a 3rd diff in the standard length chassis is that right? I know your setup is longer...
13Maschine is offline
Old 04-21-2014, 01:22 PM
  #15755
You could in the DMX410 chassis With a Shorter front/center shaft..
Old 04-21-2014, 01:39 PM
  #15756
Are you sure its the right part? Mine has a lot of room for error.
lee111m is offline
Old 04-21-2014, 05:06 PM
  #15757
With keeping the stock layout, No. If you ran a shorty across the back and ran shorter driveshafts, maybe.
Old 04-21-2014, 07:02 PM
  #15758
rcjunky1's Avatar
Sounds like the rear support posts on the front top deck are loose or missing screws, its creating too much flex in the front end.
rcjunky1 is offline
Old 04-21-2014, 09:48 PM
  #15759
S Miller's Avatar
So Im new to the Durango brand and 4 wheel mod. Had my first race and dominated all the 22-4s. In practice we have a rhythm section and found it better to quad into it. Unfortunately I cased it right on the knuckle of the landing and popped out my front drive shaft as well. Talked to some people and it seems it is a problem on those extreme situations. If you try and twist the chassis it is only front to back that moves, side to side is very stiff. If you have not held a 22-4 they don't move at all. When I get some time I will try and shim the drive shaft so it goes into the center out drive more. Might have to notch the pinion for the set screw.
S Miller is offline
Old 04-21-2014, 11:06 PM
  #15760
ekt
ekt's Avatar
I noticed you are using the aluminium servo mount, there can be an issue of the top deck moving because it doesn't have the locators that fit into the top deck hole like the plastic mount. There was a mod for it, but I'll have to try find it.
*Edit
Found it here http://www.rctech.net/forum/11408457-post11388.html
ekt is offline
Old 04-22-2014, 07:52 AM
  #15761
S Miller's Avatar
Thanks. I will have to try that.
S Miller is offline
Old 04-23-2014, 09:23 AM
  #15762
Tekin's rs gen 2 will power this buggy? I have a brand new one that I was going to sell but when I get the dex410 I would like to use the gen 2?
04sti20 is offline
Old 04-23-2014, 10:21 AM
  #15763
the incubus's Avatar
Trader Rating: 17 (100%+)
I'd suggest you sell the RS and buy something that can handle lower turn motors like 6.5 & 5.5 which are the most popular for 1/10 4wd.
the incubus is offline
Old 04-23-2014, 10:25 AM
  #15764
My rs gen 2 8.5 ran to hot for my liking, I also found it lacked. Switched it for a flow and a 6.5
lee111m is offline
Old 04-23-2014, 11:00 AM
  #15765
Ok. I was just wondering because I sold my 2wd buggy and have the tekin rs gen 2 for sale now so I wasn't sure. What other esc's work good with this buggy?
04sti20 is offline
