Like Tree22Likes
Old 04-16-2014, 11:56 AM
  #15721
Originally Posted by offroad dude
I have a v4 and I was wondering what most of you guys are running for diff oils. I'm currently running 7k front and 1k rear. However, the car is still not as planted as I like. I was thinking of going to 3k in the rear to help balance out the car. I wish I had more time to test but my track time is limited.
Thanks in advance!!!!
Im using 7kf, 3kr on medium loose clay and 10kf, 5kr on astroturf.
ridgeracer is offline
Old 04-16-2014, 11:58 AM
  #15722
offroad dude's Avatar
Trader Rating: 31 (100%+)
I run on med-loose clay and I was thinking of trying 3k in the rear also instead of 1k.
offroad dude is offline
Old 04-16-2014, 12:25 PM
  #15723
the incubus's Avatar
Trader Rating: 17 (100%+)
I'd suggest you try 10K front 3K Rear, and you can try 3500 and then 4K rear to see how it works.
I run 10/3-3.5 and run on large outdoor tracks and it's awesome. The 21 front block make the car more predictable and for me alleviated the throttle steering I had to do in oder to get the car to turn. A couple of guys with the 410 diff conversions on their 44's also run similar weight fluids but tend to drop to 7K up front depending on weather and track conditions because the car is lighter.
the incubus is offline
Old 04-16-2014, 12:55 PM
  #15724
I run the 21* hubs also. I really believe that running the 1k in the rear was way too low causing for over rotation.
Old 04-16-2014, 12:59 PM
  #15725
Originally Posted by lee111m
sick stand
Thanks!
Old 04-16-2014, 03:29 PM
  #15726
jmackani's Avatar
Trader Rating: 14 (100%+)
Where are your camber links at on the rear hubs?
jmackani is offline
Old 04-16-2014, 03:36 PM
  #15727
They are front Caster Blocks, not rear hubs.
Old 04-16-2014, 04:22 PM
  #15728
Lol... yeah I know. I'm running 1dgr rear hubs with the tower link in the 4 hole and the hub link in the 3 hole.
I know how to set up a car it just this 10th scale diff stuff is new to me.
Thanks for all the help incubus
Old 04-16-2014, 04:50 PM
  #15729
jmackani's Avatar
Move the hub out to hole number 1. It will reduce the rotation. I do not believe the rotation is coming from the 1k diff though that is low.
jmackani is offline
Old 04-16-2014, 04:52 PM
  #15730
The number 1 hole is the short link and will make car to lose traction very abrupt in the apex of the turn.
Old 04-16-2014, 06:04 PM
  #15731
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
The biggest thing I found to help with the over rotation with this car is limit rear droop 95-96mm and run sway bars 1.3 front/ 1.5 rear. What are you running now?
Bman's 3XNT is offline
Old 04-16-2014, 06:09 PM
  #15732
jmackani's Avatar
The setup sheets I just looked at show number 1 on the outside. Interesting they switched the number 1and 3 holes between the v3 and v4 setup sheets.
jmackani is offline
Old 04-16-2014, 07:23 PM
  #15733
I was working on that at the track. I went from 105 in the rear to 100 and in the front I went from 90 to about 86. I think I will take some more out.
Old 04-16-2014, 07:29 PM
  #15734
I was running 1.1 front and rear swaybars but I too the front one off.
Old 04-16-2014, 11:07 PM
  #15735
13Maschine's Avatar
sway bars Front AND rear???? Do you mind elaborating? Seems like most times you would want to run them on one or the other.
Are we measuring droop from the top shock screw to the bottom shock screw? this is essentially shortening the shock?
13Maschine is offline
