Like Tree22Likes
Old 04-11-2014, 09:24 PM
  #15691
rcjunky1's Avatar
are jcon pressure points not extremely similar?
rcjunky1 is offline
Old 04-11-2014, 10:05 PM
  #15692
the incubus's Avatar
Trader Rating: 17 (100%+)
Originally Posted by godofcable
if you're referring to the bashers in palm beach gardens florida, they closed at the end of march
Indeed they did.
Tis what happens when you overcharge for everything. I mean $18 to practice was absurd!!!
the incubus is offline
Old 04-11-2014, 10:06 PM
  #15693
pink_sleeve's Avatar
Trader Rating: 218 (100%+)
I have not been to a track where pressure points and typos work equal in Ohio
pink_sleeve is offline
Old 04-12-2014, 12:09 AM
  #15694
13Maschine's Avatar
Smile
Originally Posted by the incubus
Doesn't anyone pay close attention to my setup?!??? Lol
Don't you know you have to post the pictures twice? hahahahha
13Maschine is offline
Old 04-12-2014, 12:10 AM
  #15695
13Maschine's Avatar
Smile
Originally Posted by thephunnel
Looks good! I never thought of standing the rx on its side. Definitely a space saver.
THANKS! Took a while to make it all work This was round two...
Old 04-12-2014, 12:17 AM
  #15696
13Maschine's Avatar
Smile
Originally Posted by pink_sleeve
If your track uses aka clay typos what are you guys using for hexes to run them and is the correct offset maintained?
I just bought a set of K1 hexes to try with the 22-4 EVO wheels. I also picked up a set of B44 EVO wheels as I already have 10mm durango hexes up front and I have been using 12mm avid hexes in the rear.
I"ll post pics of the EVO wheels and the K1 hexes with measurements and all. I also have stock Durango wheels with tresrey hexes so I can post measurements/comparisons to the EVO and my current J Concepts Inverse.
I've noticed the inverse even though it's a two piece wheel is lighter than the durango wheel. I think it's about 7 or 8 grams per wheel.
Old 04-12-2014, 05:33 AM
  #15697
offroad dude's Avatar
Trader Rating: 31 (100%+)
Please do!
offroad dude is offline
Old 04-12-2014, 10:19 AM
  #15698
Originally Posted by ekt
They are a solid upgrade if you have issues with the plastic ones, note that there is a left TD310006 and right TD310007 side.
Other options are TDs weight version TD220002 and the Tresrey ones.
thanks bro. yeah im having some issues. i guess ill just get the standard durango ones. they look nice
these_savages is offline
Old 04-12-2014, 03:55 PM
  #15699
Anybody race there 410 with the front diff and drive shafts removed in 2wd class on carpet track, seems to be the trend at my local gives them a true mid motor buggy is the argument
thefan is offline
Old 04-12-2014, 06:32 PM
  #15700
I'd be nervous with this car. A lot of heat is already generated at the slipper and its split between the front and the back. And on the true mid motor thing, i dont believe in that. If its between the axles its mid motor and if its behind the rear axle its rear motor. Idk if you'd want the motor that forward anyway.
lee111m is offline
Old 04-12-2014, 08:16 PM
  #15701
Stanfsu's Avatar
Trader Rating: 294 (100%+)
Anyone using the square packs on this kit with good results?
Stanfsu is offline
Old 04-13-2014, 07:17 AM
  #15702
I don't see whythe square pack woould be any different from saddles. It just cleans up wiring a bit.
lee111m is offline
Old 04-14-2014, 04:29 PM
  #15703
13Maschine's Avatar
Smile
I've seen some weird cars with this type of setup but I don't think they are 410s…..I didn't pay much attention as mechanically speaking it seems like a ton of extra gear in between that isn't really needed. Mid motor is between the wheels….(ditto!) Rear motor is behind the wheels. I might also say that it's better to have the motor rotation in the same plane as the spin of the wheels. This way your torque vectors CAN work together and you don't develop torque steering.
Old 04-14-2014, 04:32 PM
  #15704
13Maschine's Avatar
Thumbs up
Originally Posted by offroad dude
Please do!
Would you like to join my Tire tech talk forum? I thought it might be good to post this kinda of stuff there…for more people to use. Hexes and wheels seems to be a common thing for all of us now since there is no standard…
My forum could use some love so please come one come all:
http://www.rctech.net/forum/electric...rts-sauce.html
Old 04-14-2014, 04:54 PM
  #15705
both Xray (XB4 2wd) and teamC(TM2) has car with that settings.
Last year Jorn used this setup in his wide chassis prototype and won german 2wd national.
gear friction wise, it has friction from pinion to spur (1), and bevel gear to diff ring gear(2). While traditional 4 gear transmission has pinion to spur(1), layshaft to 1st idle(2), 1st idle to 2nd idle(3), 2nd idle to diff gear(4).
the drive train may be slightly heavier with the shaft there, but those machined steel gear are also significantly stronger than any aluminum/plastic stuff in 2wd gearbox.
For current dex410, not that much of a good choice, you may want to move the saddle battery all the way to the back, side by side, to be a bit more competitive, especially when grip isn't that high.
*Xray's Tylor Vic has 80g under the battery for his xb4 2wd. And the setup runs on high traction clay track.
nicholasxuu is offline
