Like Tree22Likes
Old 04-04-2014, 09:38 AM
  #15616
I've currently got the kit pistons with 42.5 front and 45 rear. My main issue is we have some screws holding the carpet on our jumps and landings that stick up just ever so slightly. We sometimes put in a large jump maby 20'+and when my car compresses on the lip it tends to strike said screws. My thinking is going up a few steps in the spring will help eliminate this. I'm not too worried about what the pros are doing as they are not racing at my track. I also use the fredswain method to tune my kits so I'm really just wondering what would pair with the rear dark blue spring so I don't have to spend a ton of money on a bunch a springs I probably won't use.
Sodakota is offline
Old 04-04-2014, 11:07 AM
  #15617
Dino_D's Avatar
I don't think you really need to go that much higher on the spring rate. I think you just need change your pistons to a 4x1.2mm or 3x1.5 by drilling the blanks that came with your kit and using lighter oil. Remember thicker oil packs late in compression, thinner oil gets turbulent faster and creates pack earlier in the stroke allow the car to be plush yet still pack up on jumps. A lot of people end up going harder on the oils thinking it will pack, but rather all you are doing is slowing the speed of the compression, not actually creating pack. Perhaps ask Fredswain for his suggestions as you are using use setup method.
Dino_D is offline
Old 04-04-2014, 04:56 PM
  #15618
LOSI123's Avatar
Trader Rating: 63 (100%+)
Could anyone tell me what the inner and outer hinge pins are in thickness?
LOSI123 is offline
Old 04-04-2014, 06:32 PM
  #15619
rcjunky1's Avatar
3mm inner, 2.5mm outer, if I'm not mistaken
rcjunky1 is offline
Old 04-04-2014, 10:10 PM
  #15620
LOSI123's Avatar
thank you .
Dino D,
Do you know what effect it has on the V4 moving the caster block forward in the Arm? (kit position is all the way back)
I know it will effect wheelbase and ackerman and ride height etc
What would it do to ackerman? im guessing more ackerman which in theory books says less twitchy and easier to drive, but i have also read different in regards to what happens to the wheels when first turned ie:inner wheel turns in more and peopel say that will give you more turn in, which sounds like more twitchy.
do you or any one know for sure what it will do to handing.
Regards
Paul
LOSI123 is offline
Old 04-05-2014, 06:12 AM
  #15621
RC10Nick's Avatar
Going up higher in oil will cause more "pack". A fellow forum member put together quite a nice chart relating piston sizes, oil weights, dampening force, and piston velocities. At no point on the graph does going to a lighter oil yield less dampening force (I don't say pack because several forumites have ran the calculations and discovered our shocks don't reach turbulent flow. It's all laminar).
Here is the post, and the chart is attached as a spreadsheet at the bottom.
RC10Nick is offline
Old 04-05-2014, 07:26 AM
  #15622
I saw a video were two dampers was connected rod end / rod end. One with light oil and small holes and the other with thick oil and big holes. When moved slowly against each other they were moving equal, but when moved fast the one with thin oil got much harder to push than the one with thick oil. I would say that was because of pack.
ridgeracer is offline
Old 04-05-2014, 08:40 AM
  #15623
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Interesting. I would like to see the video you have a link? I believe thinner oils pack sooner.
Bman's 3XNT is offline
Old 04-05-2014, 10:53 AM
  #15624
13Maschine's Avatar
I was gonna jump in and say I don't think we reach velocities high enough for turbulent flow however I think with emulsion shocks it might be possible due to the air bubbles.
13Maschine is offline
Old 04-05-2014, 11:03 AM
  #15625
13Maschine's Avatar
We should probably use cavitation for this effect as this seems to be the technical term for this.
Old 04-05-2014, 11:31 AM
  #15626
RC10Nick's Avatar
That's because it had smaller holes. *facepalm* What you just posted is completely in line with what I said and the chart I referenced.
Given the same size and number of holes, higher weight oil always has more dampening force.
RC10Nick is offline
Old 04-05-2014, 12:55 PM
  #15627
Facepalm ?
Let us say that 25wt oil and 2x1.4 holes gives the same slow motion damping as 40wt oil and 2x1.6 holes. those two will handle very differently in high speed damping.
If it is like you say it wouldnt matter if it is 2,3,4,5 or 6 holes as long as the total volume of the holes is the same. But it matters
Old 04-05-2014, 02:47 PM
  #15628
I'm looking for a spring set that will be stiffer than stock. So I'm thinking about going with dark blue rear springs. Does anyone know what the best front spring to go with it? I'm looking for the spring that will give my car the best ballance. Basically I'm looking for a spring set that compresses and rebounds similar without oil in the shocks
Sodakota is offline
Old 04-05-2014, 03:23 PM
  #15629
RC10Nick's Avatar
Of course they will have different high speed dampening. I never said they wouldn't!
I didn't say anything to that effect either. I said smaller holes (given the same number of holes) "pack" more. I think everyone knows that.
RC10Nick is offline
Old 04-05-2014, 10:10 PM
  #15630
Dino_D's Avatar
Its a good chart and shock dyno test.
2m/s So 1m in 1/2 sec. Or 1/2m in 1/4 sec. or 25mm which is close to our ride height in 1/8th of a sec.
Normally when you are doing a static test on your car to compress the shock on the table, I would say it that it wouldn't even take 1/2 a sec to compress the shock fully down by hand. In reality over a jump the car can bottom out from a jump in a blink of eye.
Using 1.6 and 1.7 the holes are too big in most cases to even cause the oil to become turbulent at that speed of 2m/s. Lighter oil will just flow thru as I don't think the speed might be fast enough, and thicker oil becomes turbulent way later in the stroke that it requires a even higher speed to become turbulent at all. Thus the oil wt will just slow down the shaft or piston speed which is what is being shown on the chart. Which I agree.
Can that person who did that make a chart using lets say 25 or 30wt oil as a control oil and show the difference of pack using the SAME Piston hole Area?
For example. Using a static oil wt. measure 2x1.7, 3x1.4, 4x1.2, 5x1.1, and 6x1.0 which all have approx the same ratio and see. I bet pack will increase exponentially with the 5 and 6 hole combination.
I think a chart like that would be very useful for members here. What i mean by pack is when the light oil with many small holes reaches a point in the velocity where is almost creates a hydraulic lock, in which the shaft speed changes from fast to VERY slow almost at the end of the stroke which helps you from bottoming out only on very big jumps.
THanks
Dino_D is offline
