Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
#1531
oh forget it lol...it was crazy hot both were over 200. That was with a bigger pinion tho. Like a 22-23 I went down to a 18 and now the motor is at like 160 and esc at like 180...Id still like cooler temps. I havent tried the 19 pinion but that may be where the problem lies gear wise. Any suggestions? The timing advance on his setup is at 85...maybe going back to stndrd 80 advance may help.
#1532
Timing can def bring up the temps really quick. 160 on a motor I dont think is hot. Above 180 ill start looking at changing something. But the esc should be quite that hot. Do you still have plenty of speed when you geared down to the 18?
I am no expert on this car at all. I was just wondering what your idea of hot was.
#1533
are you guys trying any other ball cups? the stock ones seem soft and are popping off pretty easy on me.
#1535
#1536
I RUN the lrp sxx tc with 7.5 ballistic with a 22pinion,14 mins comes off at 155-160 and speedo is 115 or so.. my alum braces are do in tommorow for the front i just ended up ordering from the durango website but shipping was fast tho lol... i ran this buggy this weekend and it was really good no breaks in pre practice and none thru 3 qualifiers and none in the main with those plastic butter braces not bad but finally during some practice after all the racing was over we ended up breaking the front outter lmao i think that will make the 5th one now lmao so glad my alum will be here tommorow it doesnt take much to fracture that front brace thats for sure good redence plastic front braces lol if u think about it there 10.00 dollars everytime u replace it yikes... anyways over all change the ball cups and upgrade the alum braces and this car is a very nice car
#1537
where can i find a blank set up sheet and fill it out and post it on here?
#1538
I like the white Losi heavy duty ball cups. They seem to last the longest and there's nothing worse than losing a race for a dumb reason like the ball cup popped off.
#1539
#1540
Here is a blank set-up sheet:http://www.petitrc.com/setup/durango...SetupSheet.pdf
#1542
You really should not be using timing advance for anything under a 10.5, it's just not needed. And with gearing that high on a 6.5 w/ timing advance, that is definitely why it's running that hot. When I ran 13.5 in my cars with timing advance for the shootout, I geared it close to what I gear my regular 8.5 in my 2wd.
There was still plenty of speed and all was well and it performed well but Im just going to set the timing back to stndrd settings and go from there. This motor is so quick I dont think it need any kind of extra boost/turbo/ or timing advance. Standrd setting for timing on the esc in at 80....should I go lower or leave it there, what do u guys think?
#1543
Ya I can see...thats what u get for using some1's random setup lol. I was never a fan of copying motor setups from people as you never know what conditions they are ACTUALLY running them in.
#1545
OH I WANTED TO post about tightening your rear wheels down make sure you dont over tighten or you will snap your pins
i tightend mine b4 the first quali and heard a snap on both rear wheels i just thought maybe it was the wheel by the end of the night both pins were broke in half hmmmm how my car worked i still havent figured out lol
