Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
#1519
I run a 23 on my X12 7.5 there at Mohr and my temps are good (LRP TC ESC) and it has a ton of power, make sure you open up some holes on the body though. Also I think the fan helps keep the temps down quite a bit on this thing as well. I just got my Ahsari (sp?) body in before the weekend so I'll have to get that fitted up.
Reap, you still painting?
You know you can always dial down the power as well, you know....if your scared
#1523
Saw that you are in Denver. Is there a good directory of all tracks in CO. We will be moving up in the Denver area next summer. I run both nitro and electric.
BTW, I was running a Novak 6.5 Velocity R with a GTB ESC. Change out ESC with a MMP, running with 23T. Did not last more than 8 minutes without thermoing. My body is swiss cheesed out. I changed out the 6.5 to a SS10.5 running with a 24T and she finally made 12+ minutes running wind sprints out front, so it should be good for 10 minute mains. ESC temped at 186 and motor 162.
Thanks,
Tom
#1526
hey guys,
been reading some of your posts,has anybody have a dialed set up for packed clay track pretty wide open layout?wet to start and gets little loose and dusty
durango site kinda off base with the carpet and such i think
thanks
Rob
thanks
Rob
#1527
45wt front shocks
35-37wt rear
stock pistons
Proline suburbs MC compound front and rear
10k front diff
5k rear diff
wide 7'' JConcepts wing
stock shock and roll center positions
Im still experimenting but a team driver gave me this setup and it worked VERY well. I have changed the front to 7k oil and drk greens up front but as a base youll love it. Setups in general are one of those things you have to do a lot of trial and error on. But this setup felt good and I changed 2 things that I haven't even tested yet. I may just go back to what it was normally.
#1528
Blk springs all around
45wt front shocks
35-37wt rear
stock pistons
10k front diff
5k rear diff
45wt front shocks
35-37wt rear
stock pistons
10k front diff
5k rear diff
pretty close to where i am just needed to make sure it was close
#1529
Any1 here try the team azarashi body? I seems cool with that undercover but I feel as if it would create heat if the chassis was covered due to it being aluminum. but the design looks pretty cool.
#1530
Cool. let me know how it goes and what feedback u get. Im just having issues with heat. Im running an 18t pinion with randys setup on the tekin but it still seems a bit hot. I might need to run a 19 like his setup suggests. Ive cut holes in the body's front and rear air vents but I dunno what else to do. It may also have been that the day was hot in general and being that theres no AC indoors it may have aggravated it more.
motor and esc
