Like Tree22Likes
Old 01-08-2014, 12:55 PM
  #15076
the incubus's Avatar
Trader Rating: 17 (100%+)
The Exotek includes inserts as does the new one from Durango. Each track requires different settings so you'll have to figure out which one works best for the tracks you run on, but 3 is a good general starting point.
the incubus is offline
Old 01-08-2014, 03:25 PM
  #15077
dirtdog's Avatar
Trader Rating: 21 (100%+)
I have asked this a couple times. Have not had a response yet. Where is a good place to pick up the new drive line parts? Best prices ect? Regards -Tim
dirtdog is offline
Old 01-08-2014, 03:27 PM
  #15078
Usually I find tower to be the best, and I know they carrier most if not all the 410 parts.
lee111m is offline
Old 01-08-2014, 03:38 PM
  #15079
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Yup with a coupon too!
Bman's 3XNT is offline
Old 01-08-2014, 09:43 PM
  #15080
rcjunky1's Avatar
your LHS should be very close in price as well and support your local business, they mean more then you think, you'll notice when they close.
rcjunky1 is offline
Old 01-08-2014, 10:15 PM
  #15081
huzzler's Avatar
Originally Posted by socal23
So talking about abuse. I recently sold all my electronics bc I got some extra Christmas money lol. So I bought a rx8 gen2 for my dex410 as well as a new reedy mach2 7.0. Now I've been looking around and saw the tekin pro2 5200kv 4 pole and has to run on rx8 so I was thinking since I was gonna run an rx8 anyway why not run the pro2 as well. Anyone else running a 4 pole motor or running a reedy mach2 6.5-7.5 that could give some feedback. The reedy should be In the mail today but I don't want to open it if I'm not gonna run it lol.
I don't know how you will fit an RX8 in there.
huzzler is offline
Old 01-08-2014, 10:23 PM
  #15082
+1
knowitall156 is offline
Old 01-08-2014, 10:26 PM
  #15083
Mxer59's Avatar
Trader Rating: 114 (100%+)
Well I've been out of the hobby for a bit went ahead and got the v4 pre orderd it's saying mid feb. Hoping sooner does the kit include diff and gear oils? If not whats a good commen weight for diffs and shock oils as well as pistons. Have a clay track locally and out of area aswell as a few hard packed light dust surfaces.
Mxer59 is offline
Old 01-08-2014, 10:33 PM
  #15084
13Maschine's Avatar
someone was asking earlier about DEX210 rear arms fitting on the 410. I'm about to try this on my V3 since the 210 also uses larger outer hinge pins. The first thing I notice though is that I will need to use A BUNCH of spacers to make the arms fit in the aluminum hangars since the 210 arms are essentially square. I also notice that the CVD isn't as long as the V3 so it doesn't sit in the cup quite as deep as I would like. I think it would probably pop sometimes. I see updated arms and hinge pins on the V4 does it have larger outer pins? same diameter as the inner pins? Has anyone else done this? Is there a longer drive shaft that works? with the 210 hub?
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-img_2516.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-img_2510.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-img_2515.jpg
13Maschine is offline
Old 01-08-2014, 11:25 PM
  #15085
socal23's Avatar
Trader Rating: 112 (100%+)
Lol. Like this
don't even have to hack the case. Fits nice and snug. Fitted it earlier tonight since my rx8 gen2 just came in .
socal23 is offline
Old 01-08-2014, 11:28 PM
  #15086
socal23's Avatar
And the rx8 is only 1 gram heavier than the rsx. As well as the tekin pro2 HD 4 pole is 1 gram lighter then the reedy mach2 7.0. Not a bad deal. So it's exactly the same weight as a rsx and gen2 combo just smaller footprint.
socal23 is offline
Old 01-08-2014, 11:33 PM
  #15087
huzzler's Avatar
Lol. Like this
Holly crap I can't believe it fits but where is the receiver going to go?
huzzler is offline
Old 01-08-2014, 11:34 PM
  #15088
R/C Tech Elite Member
Trader Rating: 520 (100%+)
Well, I didnt use 210 arms, but I did do a similar mod to my sons car. He was a little hard on rear arms, especially the outer pins. So I bought the outer pins from a Desc410, had to drill the arms and hubs to 3mm. Hasn't broke another since..
Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-330145_piw.jpg
flame56mx is offline
Old 01-09-2014, 12:19 AM
  #15089
socal23's Avatar
Haven't decided yet. Either next to the case, or by the motor or behind the servo. I'll post picks when I'm done
socal23 is offline
Old 01-09-2014, 01:14 AM
  #15090
13Maschine's Avatar
cool mod flame. What's the part number on that one if you don't mind?
I still like the 210 arms and hubs idea since you get captured drive shafts and also big bearings. Not to mention it lines up the tie rod much nicer.
