Like Tree20Likes
Old 01-03-2014, 09:01 PM
  #15001
platgof's Avatar
Thanks, anyone running a Castle BEC with this? And how did you find room?
platgof is offline
Old 01-03-2014, 09:08 PM
  #15002
rcjunky1's Avatar
the 1258 is my go to servo in anything 1/10. Works great in the 410. I'll also be using odonnel o'lube on the drivetrain, same as sulivan dry ice, track power also makes a krytech lube (goes on liquid and evaporates to a film, works great) A seperate BEC shouldn't be needed on a 1/10 buggy, but maybe behind the servo?
rcjunky1 is offline
Old 01-03-2014, 09:39 PM
  #15003
platgof's Avatar
Has anyone tried 7.4 volts on the TG1258? I noticed the default on the Castle bec is 5.1 volts, that dog won't hunt. I already have the Castle link, so it will be boosted. Any thoughts on where to get one for a good price? and are their smaller ones available? I just ordered the Castle at my local hobby shop and found out it is programmable in 1/10ths, awesome! So if I want 6.4 volts , no problem.
platgof is offline
Old 01-04-2014, 09:18 AM
  #15004
If I put my futaba receiver on its side there should be enough room between the esc and the servo or the esc and receiver. BTW who runs a shorty in the 410. I measured my tray and it looks like its just short of 95mm. So I don't think it will fit.
lee111m is offline
Old 01-04-2014, 09:32 AM
  #15005
huzzler's Avatar
What esc are you running? Most esc's have 6 volt bec. The 1258 is plenty fast on 6v (.08). No need for an external bec.
huzzler is offline
Old 01-04-2014, 09:46 AM
  #15006
socal23's Avatar
Trader Rating: 112 (100%+)
so i was looking at bmans with the center diff and i cant help but think why i woud not be able to just run a shorty pack sideways and drill the center diff in. anyone ever concider this?
socal23 is offline
Old 01-04-2014, 11:33 AM
  #15007
13Maschine's Avatar
Thumbs up
Originally Posted by huzzler View Post
Wow I can't run anything bigger than an 18 with my 6.5 or it gets hot.
are you temp gauging your motor/ESC/Battery after your runs? If you don't have a temp gauge I suggest getting one. They are typically inexpensive and take a lot of guess work out of it. My motors get warm and many racers get HOT. I tend to drive smoother than some it seems and also I've found my speed passion ESCs run motors cooler than my Novak did. I have not tested other speedos' myself but I do temp the other racers cars and ESCs all the time.
I've also seen a few guys run their 410's with gearing too low(17/18) and this causes major wheelspin and also the motor runs very hot.
I really like the Ryobi temp gauge. 30 bucks or so. It has a 1 or 2 year warranty.
http://www.homedepot.com/p/Ryobi-Non...R001/100674438
Hope this helps!
13Maschine is offline
Old 01-04-2014, 12:37 PM
  #15008
huzzler's Avatar
Hope this helps!
Of course I have a temp gun, that's how I know it's getting hot. I do run 18t pinion I guess I could be under geared though,but i dont have a provlem with it getting hot. I mainly run on small indoor track that's why I went with 18t figured it would be better since its so small. I haven't ran my DEX in awhile so next time I bust that thing out I'll mess with the gearing to see if it makes a difference.
huzzler is offline
Old 01-04-2014, 12:40 PM
  #15009
What are your temps?
lee111m is offline
Old 01-04-2014, 12:44 PM
  #15010
huzzler's Avatar
After 8 mins motor is usually about 145-155. Esc is no problem it never gets above about 125.
huzzler is offline
Old 01-04-2014, 01:02 PM
  #15011
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Sent PM's to TLRrunner,CarlCrocco,TeamOrangeRacer
Anyone else interested in a 3 Diff 410 please PM me. I know I forgot someone....sorry.
Bman's 3XNT is offline
Old 01-04-2014, 01:50 PM
  #15012
hobdog's Avatar
Trader Rating: 19 (100%+)
That is a very normal temp to have after 8 min. The is no need worry about that temp.
hobdog is offline
Old 01-04-2014, 03:47 PM
  #15013
dirtdog's Avatar
Trader Rating: 21 (100%+)
Those temps are perfect!
dirtdog is offline
Old 01-04-2014, 04:56 PM
  #15014
huzzler's Avatar
Yeah I know that's good. If you read back I was saying if I run anything bigger than an 18t pinion I would have problems with it getting hot. Someone commented that 18t was too low. I actually never tried anything bigger than an 18t with my 6.5 but with my 7.5 it would get too hot with anything bigger. So when I threw my 6.5 with the 18t I just left it and haven't tried anything bigger because its fine.
huzzler is offline
Old 01-04-2014, 09:12 PM
  #15015
platgof's Avatar
I was temping a bit high and removed the plastic in front of the motor and it cooled down to 140*F. I am having glitching problems running a Spektrum radio and a Savox servo, so I have already ordered the BEC. I found some room beside my ESC, on the motor side. I had a blast tonight in my first race. These are so smooth around the track and make me look way better than I am. The glitching was very obvious. I noticed the wings don't last very long. Were can I get a pack of them for a good price???
platgof is offline
