Like Tree22Likes
Old 01-02-2014, 06:55 PM
  #14986
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Originally Posted by CarlCrocco
Do the front center and rear center u joints fit your 3 diff chassis. I was going to order a few things, but thought your conversion used the desc410 ones. Also what body are you using.
The rear does. I use two rears one 68mm and the older 70mm. Right now I am using the 502 bulldog but I am going to a B44.2 bulldog as I am redesigning the rear brace. I know the XB4 body will fit as well. I tried a few different ones at the track yesterday.
Bman's 3XNT is offline
Old 01-03-2014, 05:50 AM
  #14987
thephunnel's Avatar
Well I hit the track for the first time last night with my 410R. I really enjoyed it for the 4 minutes or so that I had before it broke. LOL. I kind of figured that breakage would be an issue with the R until I get some upgrades done. I'm going to upgrade as I break. So I'm going to order the aluminum FF hangar. I see that hangar uses pivot balls. Will I be ok to run the aluminum FF and the plastic FR for now? Or will the pivot balls cause the pins to sit differently requiring my to upgrade both FF/FR at the same time?
thephunnel is offline
Old 01-03-2014, 06:38 AM
  #14988
I would get both along with HD pins and be done with it.
Old 01-03-2014, 07:08 AM
  #14989
thephunnel's Avatar
HD pins? I haven't heard of these. I didn't notice anything on the TD option page. Are these from a different manufacturer?
Old 01-03-2014, 07:14 AM
  #14990
thephunnel's Avatar
Sorry, I just went back and looked. Found the HD pins. Should have done that before posting.
Old 01-03-2014, 08:49 AM
  #14991
the incubus's Avatar
Trader Rating: 17 (100%+)
XB4 body is very nice and it's so SIMPLE to paint! LOL
The Kuhler body is gorgeous but it is a difficult body to paint. For me the absolute most difficult one to date.
the incubus is offline
  #14992
Old 01-03-2014, 09:19 AM
  #14993
wittyname's Avatar
I just went through this . Took me almost 4 weeks to get the pivot bushing/balls . You can use the alum and plastic hanger no problem. I would suggest you get the alum rf while your placing an order. That one will break next and its a time killer to change out at the track.
wittyname is offline
Old 01-03-2014, 09:23 AM
  #14994
wittyname's Avatar
I am using a MIP bypass piston set up right now and am wondering if anyone else has used them ? My track is 2 hours away , so to constantly go test and tune is very hard this time of year . I would like to get in the ball park the next time I go ... Do you find you are using heavier oil ( by 10wt or more) in the front than the rear ?
Old 01-03-2014, 09:34 AM
  #14995
thephunnel's Avatar
Thanks. Looks like today is my lucky day. The lhs doesn't stock a lot of TD parts, but they actually have the aluminum FF in stock and I found 2 pivot balls from my Desc. I'll get that rf ordered up.
Old 01-03-2014, 12:48 PM
  #14996
wittyname's Avatar
Nice !
Old 01-03-2014, 02:37 PM
  #14997
CarlCrocco's Avatar
Trader Rating: 92 (100%+)
Cool Thanks!, Keep up the hard work, can't wait to try one of the 3 diff wheelers
CarlCrocco is offline
Old 01-03-2014, 03:03 PM
  #14998
dirtdog's Avatar
Trader Rating: 21 (100%+)
Where is the best place to buy the v4 drive shafts?
dirtdog is offline
Old 01-03-2014, 08:30 PM
  #14999
platgof's Avatar
Hey guys, will a Savox 1258 fit in this? I already have a 1257 in it, but have two 1258's I could use. I found some Blaster dry lube at Home Depot for like $6 that I will use on the drive line components.
platgof is offline
Old 01-03-2014, 08:43 PM
  #15000
Yes the 1258 is the same size.
lee111m is offline
