help with brushless, im retarded >
Old 01-30-2009, 08:09 PM
Jake Foz's Avatar
Default help with brushless, im retarded
Hello all, Im pretty much the most retarded person with electronics ever and I bought a stock brushless orion vortex and lrp sphere speed control, installed it and Its moving slowwwww... Im running 30c lipos and its going like 7 miles per hour.. how can I get more power? Did I do something wrong??? And could I have damaged the motor by turning it on without the sensor wire?
Jake Foz is offline
Old 01-30-2009, 08:19 PM
This might sound stupid but...
Are your batteries charged?
Happened to me when I got my Slash, something went wrong with the one NiMh I had, so went I went to my LHS I got 2 new 7-cells.
Then I found out I needed a new charger, the one I was using could only handle a 6-cell...
Grr....
howtowakeakar is offline
Old 01-30-2009, 08:21 PM
Jake Foz's Avatar
yea my batteries are charged, i tried the same battery in my truck before and its perfectly charged... i think i fried it when i installed it without the sensor wire and tried to throttle it for like 4 seconds.
Jake Foz is offline
Old 01-30-2009, 08:29 PM
Did you have to calibrate the ESC?
If you did or did not have to, you might have done something else more serious.
Old 01-30-2009, 08:41 PM
Trader Rating: 95 (99%+)
run through the speedo setup again
RobbieS is offline
Old 01-30-2009, 09:13 PM
Not having the sensor connected will not damage the motor. You need to re-calibrate.
Thopper is offline
Old 01-30-2009, 09:45 PM
Jake Foz's Avatar
even if the motor started smoking from not having the sensor cable?
Jake Foz is offline
Old 01-30-2009, 09:53 PM
Suspended
Talking AE.......................IS THE KILLER OF ALL!
Did u make sure you have a/a b/b c/c from speedo to motor and the sensor cable only goes one way into the speedo..... also what is your gearing is it on your BK2 id start with 78 spur 28 pinion or 27 pinion.... good luck........
losidriver70 is offline
Old 01-30-2009, 09:54 PM
What LRP Speed control are you using? Some of them have an auto motor sensing function. If the speed control doesn't "see" the sensor wire it thinks you hooked up a brushed motor. This will fry a brushless motor almost immediately. If you saw smoke, you fried the motor.
Bike racer is offline
Old 01-30-2009, 10:11 PM
Jake Foz's Avatar
im using a sphere with a 17.5t orion vortex.... how should i set it up to make sure its good?
Jake Foz is offline
Old 01-30-2009, 10:32 PM
Jake Foz's Avatar
could it have been a gearing issue?
i think i had the gearing at like 84 18...
Jake Foz is offline
Old 01-30-2009, 10:53 PM
Trader Rating: 43 (100%+)
you might check your radio setup. Could be turned way down. happened to me
mracer is offline
Old 01-30-2009, 10:58 PM
Jake Foz's Avatar
im pretty sure its gearing.. the biggest pinion i have is a 22 with a 78 spur and it got lots more punch and power than the 19 84... so if i get a smaller spur or stay the same and get like a 30t pinion will it be faster?
Jake Foz is offline
Old 01-30-2009, 11:01 PM
Suspended
go taller on the pinion......
Old 01-31-2009, 03:37 PM
what model are you talking about? a xxx-t?
gini@BentKneeRC is offline
