Xxxnt Swaybar? Does Losi Make One
Has anyone used a swaybar for a xxxnt? What is the part#?
Sorry rear swaybar.
A-4140 Rear Sway Bar Kit (all XX & XXT) $9.95
A-4142 Triple-X Front and Rears Sway Bar Set $12.95 Both will work and fit, just need to use some linkage collars to keep the bar from moving side to side after it's installed. Tried it out and it was pretty good and also had to run softer rear shock setup. Something like .050" bar, 35, 56, red springs for the shocks, everything else same as Drake's setup. |
thanks for the setup what kind of track are you running on
