xxx-t battery strap conflict w/ my new lipo >
Old 01-28-2009, 02:56 PM
bigbadyoda's Avatar
Default xxx-t battery strap conflict w/ my new lipo
I got a hold of a venom 5000 2c lipo the other day... While thinking how good of a deal I was getting I TOTALLY spaced out on where the wires exited the case of the battery... They come right out the middle top of the battery where the battery strap needs to be... I've been trying to think of a solution to this problem and have seen a few on here..
Battery I recently purchased....
http://www.roguerc.com/detailed.php?productid=41539
1. drill slots in battery tray and strap in it with velcro
2. I drilled out middle of battery strap to allow wires to pass through allowing the battery strap to rest in it's original position
3. make another strap out of a different material with a hole in it for the wires but a little wider so it doesn't get extremely week....
****aluminum- would you all reccomend that at all?
Reason is I've broken 2 battery straps in the same day and sheared off the nipple of the servo holder... the battery does not have much play side-side nor front-back.. So it's just really figuring out some way to hold it down.. I was trying to go around cutting the battery tray in case a crack were to appear....
bigbadyoda is offline
Old 01-28-2009, 03:28 PM
RC Dad's Avatar
Trader Rating: 26 (100%+)
Some ideas...
You might be able to slot the sides of the battery tray and use a velcro strap to hold it in.
The AE style battery strap would work much better for this, as it attaches to posts on the side of the tray. It may be possible to add long screws through the chassis and attach a T4 strap that way.
Or, crack the hard case and re-route the battery leads off to one side?
RC Dad is offline
Old 01-28-2009, 04:18 PM
action135's Avatar
slot the battery strap in the middle towards the leads. just do a long wide slot.
action135 is offline
Old 01-28-2009, 05:31 PM
Super Moderator
This is a common issue on the XXX. Need to grind the hole in the strap a little, make it oval to the rear. Needs to have some front to back give, or it gets jammed with any chassis flex.
Dave H is offline
Old 01-28-2009, 05:59 PM
ChrisWolfson's Avatar
That is a dumb spot for the lead to come out. I'd personally sell the battery and get another one. Didn't the trinity blue aluminum battery strap for the XXX have holes in the length of it to reduce weight?
ChrisWolfson is offline
Old 01-28-2009, 11:11 PM
action135's Avatar
do exactly this, but make that oval longer and a bit wider to snake your leads through. had to do that with maxamps packs too
Old 01-28-2009, 11:21 PM
bigbadyoda's Avatar
I'll post some picture... i do agree it's kinda stupid spot for it.. Most people I know run the xxxt so I don't want to give them the same problem I'm having...
I thought about the velcro strap... And I've got a xxxt cr battery strap which is wider then the regular xxxt's strap... so i'm hoping that the hole I drill in there for the dean to fit through won't have as big of and effect on the strength of the strap as it did on the other one....
I'm going to try and re-install my bluetooth driver and upload some pics of what I've done and my setup.... having trouble with it after my vista 64bit install..
Old 01-28-2009, 11:39 PM
action135's Avatar
rough idea for you
Old 01-29-2009, 12:30 AM
bigbadyoda's Avatar
pretty much just what I did... A hole just big enough for the dean and balancing plugs to go through with a little room to move...
I was unsure if an aluminum strap would be good cause if there was a cut in a wire ever or the battery arced or something
Old 01-29-2009, 07:02 AM
an aluminum strap would be ok. you just have to remove any sharp edges. If you were really worried about it you could wrap the battery leads in tape or shrinkwrap for additional protection.
The plastic strap will probably be fine though and if it does break you still have aluminum as an option.
Crazy_jay is offline
Old 01-29-2009, 07:22 AM
Trader Rating: 15 (100%+)
Default Your Servo cover
Oval out the tie down hole also. Give the Servo cover some room to move in the hole on the strap. With chasis flex you'll break the servo cover often.
uncle everett is offline
Old 01-29-2009, 10:18 AM
bigbadyoda's Avatar
well that's the reason I"ve been breaking then.. Cause it's been pretty cold here... 20-40 when I've been running outside...Not too cold but cold enough to be running outside... I've switched to my "donor car's" plastic chassis since it's got a little more play to it then graphite when really cold..
Ya, this xxxt cr strap I'm getting I"ll have to drill out the hole a little more then stock...
I just didn't know if aluminum would be a great idea if I wire got cut and came into contact with it or something.....
Old 01-29-2009, 04:52 PM
Trader Rating: 520 (100%+)
Originally Posted by action135 View Post
rough idea for you
I really like the position of the weights
flame56mx is offline
