associated b4 front axle problem >
Old 01-27-2009, 06:53 PM
Default associated b4 front axle problem
I sheared the screw head off of the screw that holds the tire on and i can't get the rest of the screw out. NEED HELP
associatedboy is offline
Old 01-27-2009, 07:05 PM
Trader Rating: 95 (99%+)
What do you mean rest of the screw out??? Y
ou mean the rest of the axle out of the steering block???
If so you have to remove the E-Clip on the back side of the steering block and then the rest of the broken axle will pull out of the steering block.
RobbieS is offline
Old 01-27-2009, 07:08 PM
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
I'm guessing your B4 has the aluminum front axles, and you used blue aluminum screws to hold the wheel on. What happened is called galling. The threads of the screw and the axle deform and fuse together. In all honesty, I'd simply replace the axle.
SpraydbySprague is offline
Old 01-27-2009, 08:06 PM
Trader Rating: 23 (100%+)
what he means is he lost the entire head on the screw. all he has is the threads stuck inside the axel.
not home is offline
Old 01-27-2009, 09:50 PM
BIG RE's Avatar
Trader Rating: 32 (100%+)
just go to the older axles that take a locknut, it will save you headaches like the one you are currently having
BIG RE is offline
Old 01-28-2009, 04:52 PM
Ah, yes, sheared I was thinking stripped screw head.
I use the Lunsford titanium axles. Check these out.
http://www.lunsfordracing.com/mm5/me...gory_Code=AXEL
The small button head screw replaces the e clip to hold the axle in the steering block.
Old 01-28-2009, 08:23 PM
wolfsbain's Avatar
i like the e-clip but hate an allen screw to take a wheel off
wolfsbain is offline
