Old 01-27-2009, 09:40 AM   #1
jasburrito's Avatar
Default Is there a better connector than Deans?
I had thought Deans connectors were the (gold stanard connector) for years.But Have had trouble with them(heat,amp draw,small solder tab,ect) Ya I know they need cleaning ect.
But is there a way beefer connector out there?
Think I,m gonna go the cc6.5mm bullet direction! Maybe set up with 1 wire shorter than other to help them not contact,whatever. For some reaon I,m good at plugging things in backwards
Someone needs to make a case for those 6.5,s like the losi!
Any suggestions?
thanks
“Team reaper” (Dunlopy,Ogie,grassman,cool jay) Holiday buggy,Grasshopper,Kyosho rocky,Rc10,jrx2,Jrx2 pro,shumacherCat',yz10,rc10gt,rc12l,tc3,mf,rc18,b4.b44, rc10gt,xxxnt,eb4s2 pro,777,8,8e,,mini cooper,F1,mbx5t E,rc8t.rc10scrs, B6d, 22 3.0 rc8 2.0 ,gmade R1,d413.
jasburrito is offline   Reply With Quote
Old 01-27-2009, 09:43 AM   #2
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
The only thing better than Deans plugs is direct soldering. Stick with the deans...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 01-27-2009, 09:49 AM   #3
Trader Rating: 19 (100%+)
Any suggestions?
thanks
I like the losi plugs which is what I use now. I also used the 6.5 bullets from castle and they worked well too. I just didn't like the bare plugs flopping around on the batteries. Looks too easy to short by accident.
Cars I've Owned: Tekno EB48 & SCT410, AE 8.2e, AE SC10 4x4, MBX6e Tekno V4, Xray 808e, Xray 8Te, Losi 810e, Losi SCTE 4x4, Losi 22, Hot Bodies Ve8, Losi 8te, and plenty of Traxxas
Sponsors: Visa, Mastercard, Amex, and my wife's bank account.
Edumakated is offline   Reply With Quote
Old 01-27-2009, 10:10 AM   #4
jasburrito's Avatar
I have not really looked at the losi,s. What size are the bullets?
thanks
Old 01-27-2009, 10:15 AM   #5
Anoobis's Avatar
Back in the day, a company called Litespeed (or Lightspeed) made battery plugs which were excellent. I used to use them for all of my batteries. When I got back into the hobby recently I noticed that the standard was the Deans Ultra plug so I have been using them. I couldn't find anything on the Litespeed plugs but the Duratrax Powerpole Connector looks exactly the same. I never had a problem with this style connector as far as overheating. They're just a bit bulky compared to the Deans plugs.
Anoobis is offline   Reply With Quote
Old 01-27-2009, 10:25 AM   #6
They are called Anderson Power Poles. http://www.powerwerx.com/ You can get them much cheaper if you do a bit of shopping around. You can also get a crimper for them which is about 90-100 dollars. Makes connectorizing stuff quick and easy.
The only connectors better then deans are bullets However they give you no reverse polarity protection. They make bullets in a lot of sizes you really need to pick a size based on the gauge wire you run.
In my opinion you'll never need anything more then a Deans. I run them in aircraft up to 12s lipo and over 180 amps burst without any problems or reservations.
Linkdead is offline   Reply With Quote
Old 01-27-2009, 10:27 AM   #7
thanks
I think they are 5.5mm. Very easy to use as they come with a plastic housing that clearly delineates between positive and negative. The only thing i don't like about them is that the bullets can push out of the housing if you push on them too hard.
Old 01-27-2009, 10:59 AM   #8
whitrzac's Avatar
Trader Rating: 95 (100%+)
you could run 2 diffrent sizes of bullets, one 6mm and one 6.5mm
whitrzac is offline   Reply With Quote
Old 01-27-2009, 11:13 AM   #9
The problem is on the battery. You have a male bullet exposed and then a female bullet. If the shrink wrap wears off on the female bullet, you could have a potential for a short. Even if one of the wires is shorter, there is still that potential.
I ran like this most of last year with CC bullets, but it really bothered me.
Old 01-27-2009, 11:23 AM   #10
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Whats wrong with deans ?
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 01-27-2009, 11:25 AM   #11
Bulldawg RC's Avatar
Trader Rating: 65 (99%+)
I personally use batteries with 4mm female internals. i then solder bullets to speed control and it is kind of like a direct connect. been running this for a year without a single problem and many guys i know do the same. Just make sure to unplug them after race in case you left the switch on by accident. Deans are nice but too many connections.
Bulldawg R/C Batteries and Products
Nimh and Lipo Batteries and accessories
www.BulldawgRC.com
Team Driver for: Proline, Team Epic/Trinity, Hex Crew, Bulldawg R/C, Speed Demon Hobbies ~~~~TEAM CRUNCHY~~~~
Bulldawg RC is offline   Reply With Quote
Old 01-27-2009, 11:33 AM   #12
That is the only thing i like about the 1/10 lipo packs is the internal connection on some of them. I wish I could find a way to do the same for larger 4s and 5s lipo packs.
Old 01-27-2009, 11:37 AM   #13
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i like the deans more than any other. i direct soldered most of the time
jamminnay is offline   Reply With Quote
Old 01-28-2009, 04:42 AM   #14
Trader Rating: 2 (67%+)
when you guys say direct solder. Do you mean solder the 2 wire ends together from say the esc to the motor? If so, could you guys give some tips on how to do this correctly? I typically use deans for minis, trx for 1/10 + 1/8, and 4mm bullets alot lately because of their dirt cheap price on everything.
I direct soldered my 9xl to my MMM and it worked ok for 5 months, but when I was taking the exc off last week, once of the connections just snapped off. So I obviosly did something wrong with that direct solder point. Any insight would be appreciated.
Dave
HopMeUp is my friend, RcBoyz is the devil.
8ight losi conv MMM 4s Neu 1.5d
8T losi conv MMM 5s Medusa 60-1600-v2
E-revo MMM 4s Feigao 9xl
losi baja lst2 mamba25
xray m18 MM pro combo
Slash VXL
Rusty VXL
Pede VXL
sampson0420 is offline   Reply With Quote
Old 01-28-2009, 05:40 AM   #15
action135's Avatar
it would be more like having wire long enough to reach from the esc to the motor, not soldering two seperate wires together. It's really no hassle at all if you have a good iron
Ashton Brewer
First Bank & Trust Murphysboro
Alpha R/c Raceway
action135 is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 21231 Today 02:16 PM
Need 3 Laptops 4 Church, tons to trade pcnutz Other Items: For Sale/Trade or Wanted to Buy 12 04-15-2009 06:28 AM
SMC 28C 4000/5000 Hardcase Lipo part 2 Danny/SMC Electric On-Road 1598 02-17-2009 08:20 PM
battery connectors murfy Electric On-Road 15 04-01-2005 02:51 PM
