Old 01-25-2009, 06:08 PM   #1
Default lipo charging ?
will i have a problem charging a 5200 mah battery with a charger that you can only type in 5000 mah in the charger also it only charges at 5 amps instead of 5.2 amps will that creat any problems. thanks for any input i am fairly new to this lipo stuff.
stealth43 is offline   Reply With Quote
Old 01-25-2009, 06:09 PM   #2
whitrzac's Avatar
Trader Rating: 96 (100%+)
no it won't be a problem, if anything else, when it peaks, put it on again
whitrzac is offline   Reply With Quote
Old 01-25-2009, 06:11 PM   #3
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
What charger are you using?
Dan is offline   Reply With Quote
Old 01-25-2009, 06:18 PM   #4
gndprx's Avatar
Trader Rating: 18 (100%+)
Actually you don't want to "re-peak" a LiPo.
Charging at 5A will just add time to the charge, the CC/CV portion of the charge will act exactly the same and cut off the charge when the battery is full. All amperage will do is affect the charge time.
The difference between 5A and 5.2A for a 5200 battery will barely be noticeable overall. Maybe to the tune of 5 minutes extra?
Carl Fisher
Team Xtreme RC
The Grove Racing Center
gndprx is offline   Reply With Quote
Old 01-25-2009, 06:29 PM   #5
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
yeh ur fine, no harm in go lower. no condition where that 200mah will help u.
R
some places where they try to put a 5000mah cap, if they gave u stink, u could show em that u can only charge up to 5000mah b/c of ur charger.
UltegraSTI is offline   Reply With Quote
Old 01-25-2009, 06:29 PM   #6
whitrzac's Avatar
I'v had a charger cut out at 5300mah when charging an 8000 pack, thats why I said to put it back on if the voltage doesnt read 8.4
Old 01-25-2009, 06:39 PM   #7
thanks thats what i was looking for. just wanted to make sure it wouldnt cause no problems just a little longer charge time wont matter right now i have the triton eq
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
RC FLIGHT brading Manila Racers 23110 12-24-2015 07:23 PM
DuraTrax IntelliPeak ICE DC Competition Charger billwilner Radio and Electronics 1944 04-10-2014 05:23 AM
Best charger of all time?! Barry White Electric On-Road 251 01-02-2010 02:13 PM
Lithium Poly Batteries - The future of R/C! Accord Electric On-Road 140 09-14-2006 04:37 PM
