Old 01-23-2009, 10:25 PM   #46
Originally Posted by Klen420 View Post
Oh they are only 10c? Isnt that kind of low? I heard for racing should use at least 30c. Whats the difference?
10cx8000 = 80 amps continuous
15cx8000 = 120amps max
Is this enough power?
f272272 is offline   Reply With Quote
Old 01-23-2009, 10:33 PM   #47
Klen420's Avatar
Edit:
Well I was talking about the 4000 packs, so its only 40 amps cont and 60 burst. If C x mAh) / 1000 = MaxAmps, wouldnt higher C = more power? Where as more mAh has more to do with longer duration?
Losi XXX-CR Xcelorin 17.5
Klen420 is offline   Reply With Quote
Old 01-23-2009, 10:44 PM   #48
Im confused a little. Where do you get the 8000? Are you refering to mAh? If so I was looking at the 4000 mAh packs.
I originally had purchased 4 of the 11.1 4000 mah batteries 10c/15c
I wired two of them in parallel to make a 11.1 8000 battery. My main concern was that would also increase my c rating. I was a dumb ass and did not pay attention to the original c rating which is not near high enough and caused the packs to get very hot and the car was slow also. I am hoping that by combining two of the I have solved my problem. I was just curious if a continuous 80 amp draw and a max 120 amp draw would be high enough. I know it works in the vxl because I have tested it. My concern is that when I get my losi 4800kv combo back from losi for the 4th time is that i dont know if it will work. Any idea of the amp draw on that losi motor?
Old 01-23-2009, 10:45 PM   #49
Integra's Avatar
ive played with my fair share of lipo's....lesson learned was to Pay attention to the C ratings.
Old 01-23-2009, 10:51 PM   #50
I have learned my lesson. I guess $80 shipped for the 4 11.1's wasnt a bad price. The thing that sucks the most is waiting almost 25 days for them to get here from hong kong!
Old 01-23-2009, 11:13 PM   #51
Klen420's Avatar
Edit:
Old 01-23-2009, 11:18 PM   #52
Edit:
c = higher flow of power (which in this case is 11.1) I doubled the capacity 4000mah x2 but left the voltage the same. I am just hoping that I doubled the c rating at the same time and also that 80amps/120amps will be enough for the losi 4800kv setup!
Old 01-23-2009, 11:31 PM   #53
Klen420's Avatar
So if i had a 2s 30c 4000mAh pack, it would be faster, but would run for less time, than a 2s 10c 4000mAh? Sorry for all the questions
Old 01-23-2009, 11:45 PM   #54
Correct. (but i am no expert)
Generally the higher the c rating the better. But if your motor is only capable of drawing 100amp as the vileneon 3500 hundred is you have some discharge rate you will never use. This is not a bad thing though. The 2s 10c will not be able to discharge fast enough at full amp draw causing the battery to overheat. This is if you are talking about your max c rating. Most batteries have a continuous c and a max c. I bet that 10 c rating is continuous and your max is around 15c on that pack.
Old 01-23-2009, 11:56 PM   #55
Klen420's Avatar
Ok thanks I appreciate the help!
Old 01-24-2009, 04:24 AM   #56
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
You can`t change the C rating . No matter how you combine the packs they can only handle a certain discharge amp .
I wouldn`t use a lipo with anything lower then a 20C rating except for a rx pack .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 01-24-2009, 07:38 AM   #57
philippinesboy's Avatar
what does c rating equal to? i dont know how this works, cuz some batteries just state the max and continuous amperage, so how do i know by max amperage what the c rating is?
Team Losi XX4 WE Brushless
philippinesboy is offline   Reply With Quote
Old 01-24-2009, 05:21 PM   #58
I am keeping the same c rating per pack! But since i am running them in parallel I have now doubled my "c" rating. This is basic lipo info.
Old 01-25-2009, 08:40 AM   #59
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
hopefully you were not using those orion 4800s, they were 15C.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 01-25-2009, 01:29 PM   #60
These are the junky winforce 11.1v 4000mah lipos for sale on ebay. Buy it now for 19.99 plus 19.99 shipping that is for two batteries!
Best Battery for starter box?? RGraves Nitro Off-Road 14 05-01-2012 02:06 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 11:26 AM
Losi 8ight Starter Box hopup Frank L Nitro Off-Road 8 12-03-2008 03:46 PM
Yeah Racing Lipo .... 0.5C charge rate?? Juanchoyo Electric On-Road 22 11-11-2008 07:32 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 07:04 PM
