Anyone have or used a Novak GTB/Velociti Brushless? >
Old 01-21-2009, 07:11 PM
Default Anyone have or used a Novak GTB/Velociti Brushless?
Would like to know who here used this setup on their electric offroad r/cs. Would like to get some pointers on the one-touch programming and why my r/c don't fully brake and won't get into reverse.
Hope there's someone out there that has or had this setup.
Danteazy is offline
Old 01-21-2009, 07:57 PM
Trader Rating: 23 (100%+)
this a first brushless system? the gtb doesnt have reverse but i am pretty sure it has a practice mode in the programing, just read your manual. brushless is a ton smoother, have you owned a system that had better breaking than before?
not home is offline
Old 01-21-2009, 08:06 PM
The GTB does have reverse, but you have to change profiles to get it.
Do you have a manual?
It describes the one touch set up better than I can.
Dave H is offline
Old 01-21-2009, 08:09 PM
tecniquin2001's Avatar
GTB does have Reverse:
Here's the infor you need, click on the link to download the manual, and it show's you what steps to take to set up the reverse and everything else:
http://www.teamnovak.com/products/esc/gtb/index.html
tecniquin2001 is offline
Old 01-21-2009, 08:31 PM
I followed the manual. The problem I am having is the first couple steps.
-Transmitter is on
-Hold the one-touch button and then switch the flip to on and the RED led does not come on. The amber stays active. Why can't I activate the one-touch process?
(Just messed with it and there are times when the car will go reverse. I'll keep tapping forward then all of a sudden reverse will activate. Then I go forward and try reverse again and nada)
Danteazy is offline
Old 01-21-2009, 08:50 PM
i just have people working at the lhs help me set mine up.
not home is offline
Old 01-21-2009, 09:00 PM
Krio's Avatar
Trader Rating: 154 (99%+)
The gtb has novaks "smart braking" which doesn't allow instant reverse. You have to leave the throttle at neutral when the car is not moving for a certain amount of time before you can pump it forward for reverse.
Krio is offline
