CC mamba max
Old 01-20-2009, 10:09 PM
Trader Rating: 18 (100%+)
Default CC mamba max
hi all,
i have a thunder tiger AT-10 and want to put a brushless set in it, i was thinking to go with the mamba max but i was thinking of racing it also but can i use the mamba max to race, what class can i go in with the different motor kv's, i dont know what they are in turns, like what is 17.5t if there is one.
any help would be great.
rhys.
speed freak is offline
Old 01-21-2009, 12:22 AM
Bugle's Avatar
They don't make a 17.5t, you can run other manufacturers sensored or sensorless 17.5t motors though.
Bugle is offline
Old 01-21-2009, 12:48 AM
thanks for your help
Old 01-21-2009, 03:25 AM
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Originally Posted by speed freak View Post
hi all,
rhys.
If your looking to run a 17.5 type class then go with a sensored speed control like LRP or Speed Passion. If you are going to run mod then the MM is going to work well for you. I would suggest the Sidewinder with the 4600 for mod seeing as it is only 130 dollars and wil be more than enough for the AT-10.
wyd is offline
Old 01-21-2009, 07:12 AM
tom_chang79's Avatar
I just wanted to throw this out there that I realized on some of the other posts regarding brushless motors. Any turn rating with a ".5" tagged at the end implies a sensored system. CC doesn't make any sensored system (yet), I believe they are working on something in the line of Mamba Max that will be a sensored system. Correct me if I'm wrong here.
tom_chang79 is offline
