Old 11-04-2003, 04:06 PM   #16
Suspended
Trader Rating: 14 (100%+)
Originally posted by KINGZJ
GT GOOD
XXXNT BETTER
Phatkat is offline   Reply With Quote
Old 11-04-2003, 06:29 PM   #17
Flash Gordan's Avatar
Send a message via AIM to Flash Gordan Send a message via Yahoo to Flash Gordan
Originally posted by phatkat
XXXNT BETTER
GT BETTER THAN XXXNT EVERYDAY OF THE WEEK AND TWICE ON SUNDAY!!!!!!!
Flash Gordan is offline   Reply With Quote
Old 11-04-2003, 07:44 PM   #18
Send a message via Yahoo to TambokGT
I would suggest to get that aluminum brake adapter......mine melted.......I use brakes a lot.
TambokGT is offline   Reply With Quote
Old 11-04-2003, 08:31 PM   #19
KINGZJ's Avatar
Send a message via AIM to KINGZJ
The xxxnt is also a good truck but for ME the gt is much better, I have owned most of the trucks out their and always end up running the gt.
KINGZJ is offline   Reply With Quote
Old 11-14-2003, 10:25 PM   #20
Send a message via AIM to 2mcgrath Send a message via Yahoo to 2mcgrath
i just traded my onroad car for soem rc10gt"s..got a question here i cranked one of them up today it has the os 12cvx and the truck will not move the engine just revs..i checked the clutch looks allright any idea what would cause this..also my dogbones look like they are just about ready to pop out at the tranny.i mean they sit at the edge i thought maybe the shocks could be a tad to long any ideas???
2mcgrath is offline   Reply With Quote
Old 11-15-2003, 11:01 PM   #21
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Does Associated have threaded shock bodies that fit the GT.
ST Racing Concepts (STRC)
Old 11-16-2003, 09:36 PM   #22
Fisher890's Avatar
What turns? Clutchbell turns Pinion doesn't= check gear mesh too far or stripped pinion.Cluthbell and pinion turn Tighten slipper clutch.Cb Pg and slipper all turn U-Joints dont. Check Gearcase. everthing turns but tires don't Dogbones not engauging shim both ends and check for stripped screwholes on the Rear A Arm mounts buy the upgrades they are worth it. Hope this helps
Fisher890 is offline   Reply With Quote
Old 11-18-2003, 10:19 PM   #23
thanks for the info..i have one more question on your diff bolt are they suppose to be 6 balls in between the washers..i think they are called diff thrust washer's..i was looking at associated's webpage and seen these..mine doesnt have 6 balls in between the washers
Old 11-19-2003, 12:56 AM   #24
HPIRACER310's Avatar
Yep, the thrust bearing assembly should have 6 of them.
HPIRACER310 is offline   Reply With Quote
Old 11-26-2003, 08:15 AM   #25
once again thanks for the help..how do you guys get your throttle return springs to work good?on mine when i adjust it where it pulls it back to idle the servo wont pull it wot..but when i adjust the spring where the servo will pull it wot it doesnt have enough tension to pull it back to idle..these are just standard futaba servo's..also i got the parts ordered for my truck and got them last friday and i have the tranny working awesome now..
Old 11-29-2003, 10:08 PM   #26
rushdude's Avatar
Send a message via AIM to rushdude
I own a xxx-nt now and I did own an rc10 gt. They are both great trucks but the xxx-nt handles better than the gt. The great thing about the gt is that its easy to work on. The xxx-nt is hard to work on but its worth it.
rushdude is offline   Reply With Quote
MST-1 Owners Post Here! StepPins Nitro Off-Road 1132 01-16-2016 05:39 PM
Odd Posts Timing Only Post by People who only post for sale section? mtx33 R/C Items: For Sale/Trade 25 06-20-2008 11:14 AM
Losi XXX-NT owners post here rushdude Electric Off-Road 114 01-14-2005 06:31 PM
T4 Owners Post Here! StepPins Electric Off-Road 338 06-10-2004 09:09 PM
Nitro RS4 3 Type SS owners post here Smoke21 Nitro On-Road 3 11-24-2003 09:00 PM
