Old 01-18-2009, 02:46 PM   #1
Trader Rating: 6 (88%+)
Default Any Monster Max cogging issues?
I am considering upgrading from the standard Mamba ESC to the Monster Max ESC for my converted Kyosho ST-R
Are there any cogging issues with the MMM as there were with the standard Mamba? Any other issues with the MMM that I should know before shelling out the dough?
Thanks.
steve671 is offline   Reply With Quote
Old 01-18-2009, 03:01 PM   #2
Cogging is problem that still exist with some slotted motor for 1/10 scale. Mamba controllers with the last software 1.17 or 1.20 for MMM are much smoother than they used to be.
If you plan to use it for 1/8 scale, don't worry MMM run slotted motors like NEU/Medusa and even most el cheapo chinese motors without problems
Mister-T is offline   Reply With Quote
Old 01-18-2009, 03:23 PM   #3
Trader Rating: 21 (100%+)
Only cogging I've seen mentioned is when rolling backwards (like down a hil that you didn't quite make it up over) and trying to go forward again. Othe than that, haven't read any complaints about cogging with the Monster.
If you'll update the firmware in your MM to the latest, that new software is supposed to all but eliminate cogging.
Duster_360 is offline   Reply With Quote
Old 01-18-2009, 04:37 PM   #4
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
with the mamba monster ESC and my neu 1512 2.5d or the Medusa 2000kv motor I had, you would see cogging on the latest software only with punch control set at zero % and deliberate miniscule throttle pull, or, a hard full throttle pull with the Neu on lowest timing, no punch control. as soon as i added in 10% or more, it went away.
I would say for this happening in racing, it has never been an issue with the mamba monster and the 1.17 software.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 01-18-2009, 07:00 PM   #5
Great, thanks.
Old 01-18-2009, 07:15 PM   #6
I just noticed that they have a built in switching BEC. Is anyone using an external BEC still, or the one built in?
Old 01-18-2009, 07:19 PM   #7
Chuck67's Avatar
Trader Rating: 36 (100%+)
Ours cog when the lipo hits cutt-off
Thanks,
Chuck
Electrics run on smoke, if you let it out they are done!
Chuck67 is offline   Reply With Quote
Old 01-18-2009, 08:43 PM   #8
choppinwood's Avatar
running on 4s 15t pinion 46spur 1/8 buggy with timing set to lowest and startup set at lowest mmm 2200kv combo IT IS LIKE BUTTA smooth as silk no cogging at any throttle input rolling backwards or anything
Nitro Toys & Hobbies
choppinwood is offline   Reply With Quote
Castle Creations Mamba/MM/MMM FACTORY Q&A thread! Joe Ford Team and Company Discussions 2371 08-07-2017 11:37 AM
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
Losi 1/8 8ight E 4wd Thread tyhodge07 Electric Off-Road 8898 11-17-2015 06:31 PM
