Old 01-15-2009, 02:24 PM   #1
JAM MaxAmps's Avatar
Exclamation MaxAmps.com's Official Stance on pack heating and bumping....
Lipo Battery Warming Devices/”Bumping” Lipo Packs: Do not under any circumstances attempt to “heat up” your batteries or increase the voltage of a pack above 4.2V per cell using these devices or techniques. Some insidious lithium polymer retailers/distributors have suggested using these devices and techniques to increase the performance of your lithium polymer packs. THIS IS NOT SAFE AND IS LITERALLY PLAYING WITH FIRE!
Devices on the market that heat up lithium polymer batteries can increase the risk of a fire. Lithium polymer cell manufacturers suggest that 140 degrees is NOT a safe temperature for a lithium polymer cell. At 140 degrees, the pack can become unstable and very dangerous. The small increase in performance is not worth the risk of a fire. PLEASE STAY SMART AND SAFE BY NOT USING THESE PRODUCTS!
Some retailers/distributors of other brands of lithium polymer batteries have suggested that their customers and racers “bump” the voltage of their packs using settings other than the lithium polymer setting on their charger. The manufacturers of lithium polymer cells suggest a voltage range of 3V-4.2V. Increasing voltage above 4.2V per cell is not safe. You should never attempt to charge your packs beyond the voltage set for lithium polymer packs on your lithium polymer charger. Using other battery settings to “bump” the voltage beyond 4.2V per cell can cause fire and injury. The small increase in performance is not worth the risk of fire. PLEASE DO NOT USE THESE METHODS!
Best regards,
The MaxAmps.com Team
Jason
CMO
[email protected]
www.NitroKillers.com www.MaxAmps.com Caster Driver
JAM MaxAmps is offline   Reply With Quote
Old 01-15-2009, 02:45 PM   #2
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Best regards,
Yea, Their dangerous enough as it is. < maxamps
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 01-15-2009, 03:02 PM   #3
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
I should have warmed my batteries up some last night. There was a significant drop in performance when the temperature hit the low 40's. I wouldn't warm them to 140, but maybe 80-100 would have been nice!
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 01-15-2009, 03:10 PM   #4
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
I think Jason's comments are directed towards those who recommend REALLY heating the packs to those excessive temperatures he mentioned.
Out here when I had time I would usually put the charged pack in my coat pocket or pants pocket and keep it warm that way (we have temps in the negatives outside, so indoors in the 40's). I doubt the human body will cause it to burst into flames, but if you see someone crisped at the track, then don't try it!
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 01-15-2009, 03:15 PM   #5
Yea i have noticed this. When i get to the track after work my batterys feel like crap for the first 5 minutes.
Old 01-15-2009, 03:20 PM   #6
Shawn Palmer's Avatar
I know I'm technically a competitior, but I'd like to (almost) 100% agree with you.
I know Jason's been directly involved with lipo for many years as well, but I was flying Lithium Ion cells even before Lipo came to the flight industry (2001ish?). I've flown/driven only Lipo ever since (8 years now - man I'm old!).
If you start at room temp (75degF), there is actually a discharge performance increase (lower IR, higher average voltage) at 85degF, 95degF, up to around 110degF. BUT - that's about where the tangible benefits end - at 110degF. Battery IR, voltage under load, cycle life - basically everything good about a lipo is irreversably damaged at any temp above 140degF (although my good friend Linger dissagrees about the exact temp that damage starts sometimes).
Pre-heating (heaven help me for saying this publicly) actually can extend the cycle life of a pack IF and ONLY if it's being used at near full discharge capacity. Aircraft use near full capacity quite often and pre-heating has been used since it was discovered to help cold weather flyers since like 2003ish. However, 10th cars and trucks almost NEVER do.
My experienced stance is anything up to 110F is OK, but anything more absolutely does nothing to increase performance, and that 140F mark is danger danger danger!
As far as increasing the resting voltage - I totally agree with NOT doing it for the same reasons as above - it is detrimental to IR, voltage under load and cycle life. If you do it, you're cheating yourself out of hundreds of good cycles from your pack.
Where I disagree with Jason, is that there are actually ZERO real benefits! When two packs start at 8.4v and lets say 8.5v, it only takes about a millionth of a second for the discharge curves (voltage under load) to become identical. If you're racing where having .2v more for a millionth of a second really matters - then by all means turn your 400 cycle lipo into a 50 cycle fire hazard, but not at my local track please! (Adrenaline Raceway and Farmers Hobby & Raceway in Tampa if you're interested )
Readers please ignore my signature - I'm here as an informative presence, not a competitive one.
Shawn Palmer
Speed Passion USA Sales Manager
USAsupport <at> King-Golden <dot> com
www.SpeedPassion.net
www.SpeedPowerrc.com
Shawn Palmer is offline   Reply With Quote
Old 01-15-2009, 03:48 PM   #7
^^ Good informative posting!
MaxAmps.com's Official Stance on pack heating and bumping.... JAM MaxAmps Electric On-Road 33 01-17-2009 07:53 AM
