Old 10-27-2003, 05:35 PM   #1
Default Setup tips for XXX-NT
I am running on a hard packed rough and sometimes dusty track. I have holeshot rear tires and the stock front tires. The truck has large ammounts of under steer and could a little more rear traction. Please give me any set up tips you have. Thanks.
igkyoa is offline   Reply With Quote
Old 10-27-2003, 07:51 PM   #2
Trader Rating: 42 (100%+)
I RUN ON SIMILAR CONDITIONS POST YOU WHOLE SETUP LIKE SHOCK WT CAMBER POSITIONS WHAT IS THE DOMINATE TRUCK AT YOUR TRACK GT OR XXXNT IS THE TRACK DRY OR WATERED IS THERE BIG JUMPS OR SMALL ONES IS IT A HIGH SPEED TRACK WITH SWEEPING CORNERS OF A SLOWER LAYOUT HOW WOULD YOU RANK YOU DRIVING EXPERT NOVICE INTERMEDIATE WHAT MOTOR ARE YOU RUNNING I THINK I CAN HELP YOU OUT POST YOU INFO
KEITH is offline   Reply With Quote
Old 10-27-2003, 08:15 PM   #3
Kiiski's Avatar
Wow,
that gave me a headache.
Anyway, have you gone to Losi's website and checked out the setup sheets there? The first thing you should do is check to see what everyone else is running as far as tires. That is the number one consideration as far as traction, secondly ask the local fast guys what setups they are using. They should be able to help you out better than most others as they have been running that particular track.
Kiiski
Kiiski is offline   Reply With Quote
Old 10-28-2003, 05:05 PM   #4
HEY JOE I WAS JUST TRYING TO HELP THIS PERSON OUT I USE LOSI WEB AND TALK TO THE TEAM DRIVERS REGULARLY ON SETUP THATS WHY I NEEDED TO KNOW THE INFO I REQUESTED NOW GO TAKE SOME CHILDRENS MOTRIN FOR YOUR HEADACHE AND HAVE MOMMY TUCK YOU IN!!
Old 10-29-2003, 07:04 AM   #5
Essentially you should do as Kiiski recommended. Since every track is different you need a base set up which you can get from the Losi site. Tire choice will depend on the track, see what is used by the "fast" guys and get the same. Don't be afraid to ask for their set ups, most of the time they will share it with you.
Have fun racing!
AreCee is offline   Reply With Quote
Old 10-29-2003, 07:09 AM   #6
Let's not flame each other here and I'm not one of the grammar police. However, your post is a most difficult post to read since you elect not to use punctuation to separate your run on sentance and using all caps is the equivalent of shouting. So don't have a tantrum, count to ten and learn how to use the caps lock button and throw in a few periods, commas, hyphens, etc.
Also your response above was very juvenile, so who is it that should have their mommy tuck them in?
Respectfully yours,
AreCee
Old 10-29-2003, 04:02 PM   #7
the track is very dry but they use what looks like nitro fuel to wet it in some places. the track is very techinical and is hard to maintain a lot of speed. the key to the track is maintaining speed in the tight corners of which there are 5 that make 180 degrese and about 3 or 4 that are about 90 degreese. Anyone who can take these tight corners with speed and carry it can win.
in order to stay off the wall I need to take the turns very slow or hit the brakes hard and swing the back arround. both ways i end up coming out of the turns slower then many of the drivers.
thanks for the help i will check out team losi right away.
Old 10-29-2003, 04:59 PM   #8
A GREAT STARTING POINT WOULD BE ADAM DRAKES ROUGH SLIPPERY TRACK SETUP I WOULD TRY IFMAR STUDS (RED COMPOUND) REARS WITH STOCK FOAMS AND GO FROM THERE THESE TIRES I HAVE FOUND HARD TO COME BY ALSO I WASNT TRYING TO FLAME ANYONE SORRY FOR THE TROUBLE JUST TRYING TO HELP OUT A FELLOW RACER
Old 10-29-2003, 07:15 PM   #9
i looked at adam drake's rough slippery track setup and i think it will suit my needs very well. most of the setup uses stock parts so all i have to buy are some new springs and shock oil.
thanks for all the help everyone!
Old 10-30-2003, 07:41 AM   #10
Kiiski's Avatar
igkyoa,
Keep us posted on how things work out for you.
Kiiski
Old 11-02-2003, 02:21 PM   #11
i looked at the setups at team losi and made a combination of them that i hope will work out better then my old setup.
XRAY T 2 08' setup tips. RcXtion Malaysian R/C Racers 0 05-14-2008 11:17 AM
SETUP TIPS FOR TX/RX rcabj Malaysian R/C Racers 41 01-13-2008 01:55 AM
need setup tips to cyclone Rasmus TbEvo IV Electric On-Road 8 06-22-2006 04:16 AM
B4 setup tips dado11g Electric Off-Road 28 07-26-2005 11:21 PM
setup tips? buddha Wisconsin & Illinois Racing 4 02-03-2005 01:47 AM
