Old 01-09-2009, 08:00 AM   #1
Default B4 diff question
The differential on my b4 sounds pretty smooth but every now and then there will be an ugly grinding metal sound or plastic on metal, is it because maybe the tranny needs to be relubed? or the diff needs to be remade?
aquafina1 is offline   Reply With Quote
Old 01-09-2009, 08:33 AM   #2
d4man's Avatar
Check your diff for tightness....Re-tighten if necessary...If your diff is tight, tear the tranny apart and inspect everything.
d4man is offline   Reply With Quote
Old 01-09-2009, 08:55 AM   #3
ms3 Chris's Avatar
Also, you do not need to worry about lubricating the gears, as they self lubricating (oil impregnated). You can still add a drop of oil if you want, but excess grease/oil will just add drag and attract 'grime'. Also, check that your pinion and spur are meshed correctly- if you have them a little too loose, the noise you are hearing is the pinion spinning on the spur.
Chris Shieldsmith
Hot Bodies Racing www.hotbodiesonline.com
Tekin www.teamtekin.com
Team Checkpoint
ms3 Chris is offline   Reply With Quote
Old 01-09-2009, 09:15 AM   #4
trickedyfz450's Avatar
I would start by checking the tightness of your diff, if that seems fine It might be that your slipper is to tight and its not slipping and it being to tight is causing the diff to slip. This would make like a "barking" sound. Good luck!
Bumps And Jumps Rc
trickedyfz450 is offline   Reply With Quote
Old 01-09-2009, 10:11 AM   #5
I have no slipper since im using the spur adaptor so i can run a 68 spur on their and the diff is tight but it still makes the noise
Old 01-09-2009, 10:33 AM   #6
d4man's Avatar
Your diff is toast then, and possibly the diff gear. The noise you hear is probably the diff rings rubbing the diff gear because the diff balls are smaller then when you started out. Replace diff balls, dff rings and the gear to be safe.
Old 01-09-2009, 12:53 PM   #7
Trader Rating: 15 (100%+)
Default Thust bearing
Check your thrust bearing.
uncle everett is offline   Reply With Quote
Old 01-09-2009, 01:37 PM   #8
B-FAST R/C's Avatar
+1
www.bfastrc.com *** Feel The Diff!! ***
arcshobbies mcculloughsrcracing
B-FAST R/C is offline   Reply With Quote
Old 01-09-2009, 01:51 PM   #9
When you say "every now and then", the diff can slip under high load, that's what it's there for. It makes a "barking" kind of noise if it's set properly, and sounds AWEFUL, but it's doing no harm.
THey key is, the slipper should be whining whenever you give it full tits from a stop or on high-bite surfaces, the diff should only "bark" when you swing into a tight turn at speed.
JR007 is offline   Reply With Quote
Old 01-09-2009, 02:23 PM   #10
CCristo's Avatar
Trader Rating: 55 (100%+)
The diff should never slip. That's what the slipper is for... to protect the diff. Allowing the diff to slip puts flat spots on the diff balls and grooves in the rings. After that it'll never be smooth again.
Time to order up some silky smooth BFast balls & rings
CCristo is offline   Reply With Quote
Adelaide Nitro Offroad Racing Club oblivion Australian Racing 19737 12-11-2017 03:16 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Losi BK2/MF2 thread DerekL Electric Off-Road 2850 07-18-2010 11:59 PM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
Any offroader in Penang Island. tkhoo Malaysian R/C Racers 3675 09-16-2009 10:13 AM
DF-03 Dark Impact Questions akuhon Electric Off-Road 24 08-28-2006 03:17 AM
