Old 10-25-2003, 10:33 AM   #1
LosiFromHell986's Avatar
Send a message via AIM to LosiFromHell986
T3 Rear End Clicking....Stumped?
Hey Guys
My RC10T3 is clicking in the rear end, I'm completely stumped.
I tried:
Lubing the dogbones
checking for rocks in the spur/pinion
checked all gear mesh
BTW I'm running a Trinty Retro Series 12x2 if that makes any difference to an answer... LMK, Im completely stumped on this one
Thanks,
Jeff
LosiFromHell986 is offline   Reply With Quote
Old 10-25-2003, 03:52 PM   #2
jonski's Avatar
Trader Rating: 243 (99%+)
Things to check....
Make sure your motor screws aren't too long and hitting the armature.
Also check to make sure the axle pins aren't hitting the spur gear cover.
Jon
First RC car was a RC10T - 1992
jonski is offline   Reply With Quote
Old 10-25-2003, 04:29 PM   #3
I have had that problem before. And what was causing my problem was the inside spokes on the rim were hitting the rear hub carrier. This happened most often with pro-line velocity rims. If that ends up being your problem make sure your wheels are not screwed on too tight and that the roll pins in your axles are not bent. Hope this helps.
RMD17 is offline   Reply With Quote
Old 10-25-2003, 04:35 PM   #4
It can also sometimes be a too tight diff,which causes the cvds/dogbones to bind in the outdrive and then pop free.
saints1115 is offline   Reply With Quote
Old 10-25-2003, 11:14 PM   #5
losi jon's Avatar
RMD17 hit it right on the head,what i used to do was take a dremel and grind a little bit of material off the spokes,wont hurt the wheels at all.
losi jon is offline   Reply With Quote
Old 10-26-2003, 07:57 PM   #6
ALSO CHECK THE GEARS IN THE GEARBOX. IT IS NOT 100% COMPLETELY SEALED. I HAVE HAD THAT PROBLEM ON MY LOSI CARS AND FOUND IT TO BE THE GEARS IN SIDE.
mstng87gt is offline   Reply With Quote
Old 10-30-2003, 06:47 PM   #7
Check the pinion and spur for missing teeth.
SCREAMIN_GT is offline   Reply With Quote
new to nitro...and a bit stumped Ripskip Nitro Off-Road 6 08-25-2008 09:52 AM
SLIPPER CLUTCH MAKES A HARSH CLICKING NOISE!!! HELP!!!!!!!!!!!!!!! jatoman1992 Nitro Off-Road 2 07-30-2007 08:18 AM
clicking motor tracebeau Rookie Zone 5 04-21-2004 04:33 PM
Nitro motor clicking noise Roger Nitro On-Road 6 07-30-2003 08:03 PM
XXX clicking in the rear end ??????? HELP teamlosi4life Electric Off-Road 5 07-10-2003 11:59 PM
