Old 01-05-2009, 02:03 PM   #1
Trader Rating: 22 (100%+)
Default Which Lipo????
I am wnating to get my first lipo. But I have confused myself. I race stock 1/10 truck. What size lipo should I get and what does the C rating mean. Such as 20c 25c etc... I was thinking of getting something around 3200 to 4000mah. Just to keep the price down a little is there a good budget friendly charger out there that is also safe.
ghj1997 is offline   Reply With Quote
Old 01-05-2009, 02:28 PM   #2
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
C is the max discharge rate. 15C is fine for 1/10 scale, but not recommended for 1/8. I'm racing 2WD truck class w/ $35 batteries. http://www.amainhobbies.com/product_...ducts_id/16867
Those batteries are awesome for the money.
As far as a charger, I think the Triton Jr is probably the best quality at a low price. I recommend buying a nice charger w/ balancing built in for lipo though. Lipo can be dangerous if not taken care of properly, why risk your safety over saving some money. Buy a nice charger.
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 01-05-2009, 05:07 PM   #3
Trader Rating: 23 (100%+)
my all time favorite lipo is the orion 3800 lipo. the thing has a ton more power than my 4900 trakpower. it's lighter and clears every jump needed.
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 01-05-2009, 06:12 PM   #4
Trader Rating: 21 (100%+)
Lipo C rating is supposed to be the amps the lipo is capable of producing on a continuous basis. A 15C rating on a 4000mah means its should produce (4000/1000 x 15) 60amps. There is also another rating, the burst rating, which is not mentioned as much, but its the current the lipo is capable producing for a short period, usually 30sec. Burst rating is higher than the continuous rating. This example could have a 20C burst rating meaning it could produce 80amps for a short period.
A drawback to lipo is the charger, a diff one is needed and it should have a balancer so the individual cells that hook together to make the batt start at the same voltage. There is less of a chance of overdischarging a cell if the cells start balanced (equal voltage). Overdischarge can damage lipo to the point it is ruined and a safety hazard until properly disposed of.
Good AC/DC charger, has balancer builtin -
http://www.amainhobbies.com/product_...ducts_id/18361
Duster_360 is offline   Reply With Quote
Old 01-07-2009, 10:45 AM   #5
I have been using a Hobbywing Tekmodel 60A esc with nimh batteries and has worked very well. The next question I have is will a 20c 4000mh lipo kill my esc or should it be fine. I am running a Novak 10.5 motor.
Old 01-07-2009, 10:46 AM   #6
rcterp's Avatar
Trader Rating: 35 (100%+)
Buy SMC batteries, they may not be the cheapest but they're definitely the best you can buy.
rcterp is offline   Reply With Quote
Old 01-07-2009, 11:09 AM   #7
foolio's Avatar
Originally Posted by rearviewmirror View Post
...Lipo can be dangerous if not taken care of properly, why risk your safety over saving some money. Buy a nice charger.
Okay, I'll bite. Why recommend a cheap soft case lipo if safety is a concern?
Go for something like Orion, Checkpoint, SMC, Trakpower etc. They cost a little more but the hard case will reduce the chances that the case is compromised which could cause catastrophic failure.
foolio is offline   Reply With Quote
Old 01-07-2009, 11:45 AM   #8
gndprx's Avatar
Trader Rating: 18 (100%+)
If a hard case inexpensive LiPo is the goal, I have nothing but good things to say about Yeah Racing packs.
I've used most packs on the market and although some such as SMC do make a difference in an application such as Oval or On-Road racing, for Off-Road racing there is just no noticeable benefit to the more expensive packs.
The 3200 or 4000 are more than enough for stock truck. The 5000 is more than enough for any class you will run. I have one paired to a Novak 4.5 brushless in 4wd mod and it does just fine.
Carl Fisher
Team Xtreme RC
The Grove Racing Center
gndprx is offline   Reply With Quote
Old 01-07-2009, 11:49 AM   #9
gndprx's Avatar
For chargers, a few good budget LiPo chargers would be:
Triton Jr.: http://www3.towerhobbies.com/cgi-bin...&I=LXMAH9&P=ML
or
Multiplex LN-5014: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKSY1
I have used both and currently keep a triton jr in my pit box as a backup to my other chargers. Works like a champ.
Carl Fisher
Team Xtreme RC
Old 01-07-2009, 12:42 PM   #10
Because the chassis more than protects the battery, we're not talking about airplanes here.
Old 01-07-2009, 01:52 PM   #11
Check out the Turnigy charger from hobbyking.com. I use the Accucel-6 and it's fantastic. For $40, it's a bargain!! It's the same OEM unit as some Venom's and Trinity's that cost about $150.
Also, they sell a 4000mah hardcase pack for $28. It's a steal at this price. The wiring harness it ships with would run you $10 alone!
f00fy is offline   Reply With Quote
Old 01-07-2009, 02:02 PM   #12
gndprx's Avatar
Do you know that for sure? I've run across that charger once or twice online but that price REALLY makes me skeptical.
Carl Fisher
Team Xtreme RC
Old 01-07-2009, 02:16 PM   #13
Do I need a power supply and which one would work with this charger.
Old 01-07-2009, 02:50 PM   #14
THE 15 AMP RAIDO SHACK POWER SUPPLY WORKS GREAT
todd1 is offline   Reply With Quote
Old 01-07-2009, 02:54 PM   #15
Dan/Ultraline's Avatar
Send a message via AIM to Dan/Ultraline Send a message via MSN to Dan/Ultraline Send a message via Yahoo to Dan/Ultraline
ghj1997 we can set you up w/a battery.
http://www.ultralinehobbies.com/inde...parent=72&pg=1
Also a great Charger.
http://www.ultralinehobbies.com/inde...=603&parent=20
Give us a call or email with any questions.
Dan Filbert
Dan/Ultraline is offline   Reply With Quote
Tekin RS/RS PRO on 1s Lipo Q&A Randy_Pike Electric On-Road 1153 12-07-2016 09:18 AM
1s Lipo Battery Options?? pejota Electric On-Road 139 03-03-2010 03:38 PM
Best saddle pack lipo for B44 desertraton Electric Off-Road 65 02-03-2010 10:03 AM
New lipo competiter "Cheapest & Fastest" R.Fenstermacher Electric Off-Road 69 09-01-2009 08:52 PM
1/10th 4wd buggy which one? vwjuice Electric Off-Road 83 08-26-2009 12:24 AM
i need a ac/dc lipo charger/balancer ibmenace R/C Items: Wanted to Buy 10 08-13-2009 01:59 PM
