Old 10-22-2003, 10:35 PM   #1
Team R's Avatar
Default Finding a substitute brake wire for my XXX-NT
Iím looking for a threaded wire to replace the brake Z-bend wire on my NT. So it is easier to make fine adjustments to the brakes. I heard the Ofna my have what Iím looking for, but I donít have a part number. I have not had a chance to get to my LHS to see what type of Du-bor items they may have, but I thought I would get some input before I did so.
Thanx for all information sent my way
Team R is offline   Reply With Quote
Old 10-23-2003, 10:02 AM   #2
SlobbaTech's Avatar
Serpent and other on-road gas TC's like to use a threaded brake linkage, so check those out. If they are not the right length you can use an airplane linkage, will have to cut and bend it yourself and it's aluminum, I haven't had any problems with it bending from normal use.
SlobbaTech is offline   Reply With Quote
Old 11-05-2003, 10:39 PM   #3
Send a message via AIM to 2mcgrath Send a message via Yahoo to 2mcgrath
if your talking about a threaded adjustment to just turn to tighten or loosen brakes hpi's have them
2mcgrath is offline   Reply With Quote
Old 11-06-2003, 01:11 AM   #4
KINGZJ's Avatar
Send a message via AIM to KINGZJ
The mst-1 wich is very similar to the losi setup uses a threaded adjuster
KINGZJ is offline   Reply With Quote
Air Filter Oil Substitute stoptherockets3 Nitro On-Road 10 01-29-2008 05:49 AM
Ozite Substitute ? nitrotruckn Electric On-Road 10 11-15-2006 08:05 AM
ECS- Auto brake/Neutral Brake/Drag brake RC12L3a Electric On-Road 6 11-21-2004 10:10 PM
drag brake, brake and reverse imjonah Rookie Zone 3 07-24-2004 07:20 PM
Anyone know where to buy "26 Awg, 22 Stranded Wire" or typical antenna wire? Thanks Shrub Electric On-Road 9 04-16-2004 05:57 PM
