Lipo cutoff, Voltage or Capacity > Lipo cutoff, Voltage or Capacity
Old 01-03-2009, 07:29 PM
brofroe's Avatar
Trader Rating: 20 (100%+)
Default Lipo cutoff, Voltage or Capacity
I read most places that lipo cutoff should be 3.0 volts per cell maximum. I have also read in one place to only discharge them to like 80% of capacity. Which is right?? I'm new to electric much less lipo. I ran my 6s 5000mah pack to @ 3.5 volts per cell the other day and it still had plenty of punch. When I charged it it took 3980 mah to charge it, which is right at 80%. Some of you pro's staighten me out please If you do use voltage is it under load 3.0 volts or what? I currently have my MMM set at 19volts which is 3.17 volts per cell. HELP please, I don't want to waste my battery.
Thanks in advance.
brofroe is offline
Old 01-03-2009, 09:13 PM
Super Moderator
They are both right, just saying different things. Need to stay above 3 volts per cell minimum. Go below this the battery may not charge back up. Immediate failure concern.
The 80% discharge comes before that, and is recommended for longer battery life and fewer out of balance issues. More of a long life issue.
Dave H is offline
Old 02-16-2009, 06:28 AM
brofroe's Avatar
OK I've set my LVC to 3.5 volts per cell and don't even ever reach the LVC point. However i'm still using over 80% of capacity. In fact, once I recharged to over capacity. Info please.
brofroe is offline
Old 02-16-2009, 06:39 AM
whitrzac's Avatar
Trader Rating: 96 (100%+)
common misconception, damage happens under 2.5v
don't worry about the batt, leave the lipo cutoff at 3.5 and your good to go.
the 80% is so it "supposedly" puts less stress on the batt
whitrzac is offline
Old 02-16-2009, 07:45 AM
Miller_Time's Avatar
Trader Rating: 11 (92%+)
It sounds like your LVC is either not turned on, not set correctly, or not working properly then. 3.5v per cell should be a pretty early cut off and if you still can put back in more than it's listed capacity something is wrong. It's also possible that the cells are very much under-rated and their actual capacity is higher than listed, but to be that far under-rated would be suspect.
If you have a digital multimeter, check the total pack's voltage next time after a run, and divide that by the number of cells. If that's lower than 3.5v then your LVC is not on or not set at 3.5 volts.
It's important that you check it as soon as possible after a run and with no load. The cells will "bounce back" and gain some voltage as they sit without a load. Also the cells will drop under a heavy load and quickly regain some voltage even before you can get a meter on them, so the actual voltage under load would have been lower than what you read.
Miller_Time is offline
Old 02-16-2009, 11:12 AM
Dont use the LVC to tell your runtime at all. Set it at like 3.2 which is still safe. If you set it to high and you punch the throttle the voltage could drop that low depending on how much juice is left and the ESC is cut power while your driving. Use a timer and find the magic time that keeps in at the safe 75-80% range.
Speed_Freak_039 is offline
Old 02-16-2009, 11:34 AM
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
3.0 is safe... Damage begins < 2.7v per cell.
rearviewmirror is offline
Old 03-23-2011, 09:32 AM
djroberts's Avatar
It also seems like it would depend on the performance of the battery. For instance setting LVC at 3v on a Thunder Power would go way beyond the 80% rule due its ability to hold voltage. They hover around nominal voltage for a long time then slowly decrease to about 3.5. After that the voltage tanks and the battery is almost dry.
At 3.5v however its still got some capacity left but on cheap batteries that don't hold their voltage it may cut out too early.
I'm operating on uneducated logic here so please correct me if I'm off base.
djroberts is offline
Old 03-23-2011, 10:56 AM
Super Moderator
To some extent yes. Itís mostly about maintaining sufficient resting voltage from all of the data I have seen. A lot depends on the load the battery is under, how much the voltage is sagging under load. This impacts the actual state of discharge. Higher amp discharge rates (relative to battery size) can tolerate a lower voltage under load. Conversely lower loads need a higher shutoff.
Dave H is offline
Old 03-23-2011, 11:02 AM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
I understand this but I'm betting you get some questions...
racer1812 is offline
Old 03-23-2011, 11:04 AM
Super Moderator
With all due respect I sure would like to see some hard proof of these claims with some cycling (the 2.7 & 2.5V part). I’ve seen a lot of lipo data, 300 cycles using ~3.2V or higher cutoff is not uncommon with little reduction in performance with quality lipos. I’ve never seen very good life taking cells that low (again 2.7 & 2.5V) regularly. Not to mention due to the way lipos dump there is very little run time difference, and going that low frequently results in at least some if not considerable imbalance. Take a 2S to 5.4V and I strongly suspect one cell is well below 2.7V for example, a 4S would likely be worse, etc.
Dave H is offline
Old 03-23-2011, 11:06 AM
Super Moderator
No doubt, the left flank is rather exposed eh?
Dave H is offline
Old 03-24-2011, 02:27 PM
djroberts's Avatar
Makes sense to use voltage since we're concerned about electric potential and its affect on capacitance. I guess I guess the variable here is performance and run-time. Personally based on my analysis I'd probably set my LVC at 3.4v. Currently I have a VXLs so I'm not sure what it uses.
Usually when I'm ready to take a break there's still about 3.6 on my Gens Ace so I rarely hit the LVC.
Old 03-24-2011, 05:46 PM
jamminroger's Avatar
i use zippy 4 cells 30c 5000mah on my sc8e and my mugen mbx5t. i used to have my lvc at 3.0v per cell and my batteries would puff. now i have them at 3.6 volts per cell and my batteries are not even hot. i know 3.6 is probably too high, but i would rather save my batteries. they also charge much sooner than 3.0 lvc. so, if you have enough batteries, higher lvc is not a bad idea. i have seven batteries and it lasts me 4 hours at the track.
jamminroger is offline
Old 03-24-2011, 05:55 PM
bigben1165's Avatar
agree completely, also the comment on the rebounding of battery voltage is very good advice too. you will hear many different variations on a similar theme. i err on the side of caution, worse case scenario is that you dont get as much run time, best case, you get to keep an expensive lipo useful for 200-300 cycles.
bigben1165 is offline
