Old 01-02-2009, 06:56 PM   #1
Default cogging
I got a slash used with the vxl brushless setup in it and ran it one time and it would run but seem like it was cutting out and would not run very fast.Now the only thing it will do when the rear wheels are o nthe ground is just jump or cog I guess.Does anyone have any ideas on how to fix it or am I just screwed
gasfreak is offline   Reply With Quote
Old 01-02-2009, 07:06 PM   #2
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
What kind of batteries are you using? Lower quality betteries will do that...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 01-02-2009, 07:11 PM   #3
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Cogging happens for a few reasons. Low end batteries are common cause of cogging. 2ndly is poor battery connectors is another reason. If the battery is not charged up to full power can cause cogging as well as the receiver not getting enough power when you first his the throttle will casue the car to stutter.
In this case I would bet if you use a better battery it will stop doing that.
With all the new brushless systems coming out and the price of cheap Nicads or Nimh packs coming way down because of lipo packs this is becoming more of a commen problem.
ST Racing Concepts (STRC)
Old 01-02-2009, 07:13 PM   #4
the batteries that I have are really old and have had a hard life I used to run them in my brushless boats.So I have 2 new ones coming in the mail hopefully tommorrow so do you think that will fix my problem
Old 01-02-2009, 07:49 PM   #5
jmcvicker's Avatar
New, fully-charged should help. Did you go with 7-cell batts?
jmcvicker is offline   Reply With Quote
Old 01-02-2009, 07:55 PM   #6
they are 6 cells but I might by 2 more cells and make both of them 7 cell packs how many cells will the vxl 3 esc take
Old 01-03-2009, 09:23 AM   #7
Trader Rating: 21 (100%+)
Up to 9 cells.....
SPECS: Input Voltage: NiCad/NiMH 4-9 Cells (4.8 to 10.8 Volts DC)
LiPo 2-3 Cells (7.4 to 11.1 Volts DC)
Duster_360 is offline   Reply With Quote
Old 01-03-2009, 04:20 PM   #8
Hey I went and bought a brand new battery I have some ordered but could not wait.It ran a little better for about 2 minutes then started doing the same thing again,it will just cut out past half throttle and when it is not very fast and after about 4 minutes it will not even take off just sits there and jumps what do you think.I mean will these things even run on 6 cells or what
Old 01-03-2009, 08:13 PM   #9
wyd
Tech Legend
wyd's Avatar
Then it is more than likely the battery plug or the motor plugs. Mine did some funny stuff like that. I went out for a race and it was perfect. When I went out for my next heat race it went around the track once perfectly. The race started and went 3/4 lap and started cogging. Put on new battery plugs as my bullets where worn and it never happened again.
Old 01-04-2009, 07:05 AM   #10
brand spanking new deans connectors both ends and it still does it
RC10B4/T4 Forum DerekL Electric Off-Road 14339 12-13-2017 11:20 PM
The Speed Passion Thread memix Electric On-Road 13377 11-28-2017 11:06 PM
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
Hobbywing ESC's Drift_Buggy Radio and Electronics 827 03-30-2016 11:43 PM
Losi 1/8 8ight E 4wd Thread tyhodge07 Electric Off-Road 8898 11-17-2015 06:31 PM
Hot Bodies Cyclone D4 EP buggy Mike Schumacher Electric Off-Road 1921 10-06-2014 12:33 PM
Team Orion Vortex Brushless motor Aku-Man Electric On-Road 719 05-27-2011 03:46 PM
