gearing question
gearing question
what pinion should i run if i have a 86T spur and im running a ss5800 brushless setup at 7.2 volts? ill be running for 30 minutes at a time and dont want to have it shut off from getting to hot
34 views and no one can help?
well i just went on the novak website and it list that i should have a final drive ration of about 10.5 for the motor i want to run, so i was able to download my manual for my truck and figure out i need a 20 tooth pinion and a 86 tooth spur to get a 10.44 final drive ratio, so thanks for trying but it looks like i just needed to search harder
i will be running it in a xxx-t same exact setup as your son only 86t spur instead of 84 which means the final drive will be .2 different which hopefully wont make a big difference
