Old 12-31-2008, 12:08 PM   #1
Default Diffs with brushless
What diff fluids are you running with the BL systems? I am thinking lighter fluids to absorb some of the instant shock of the high start torque? Is anyone having issues with ripping diffs apart for the same reason (torque)?
Thopper is offline   Reply With Quote
Old 12-31-2008, 12:14 PM   #2
kufman's Avatar
I will assume you are running a 1/8th buggy since I don't know of too many 1/10th scale buggies that have fluid filled diffs. I run 5k-7k-3k in my RC8 (Front-Middle-Rear). I have the center diff shimmed according to RCPD's instructions and so far I haven't had any trouble with diff blowouts
kufman is offline   Reply With Quote
Old 12-31-2008, 12:45 PM   #3
Yes ,8th scale mbx6. What are the rcpd innstructions? Are they rc8 specific?
Old 12-31-2008, 12:53 PM   #4
kufman's Avatar
They are special for the RC8 using a Kyosho plastic spur gear. You could apply the principle to other cars if you feel that the diff has a lot of slop on the spider gears. Bascially it adds additional shimming washers to the spider gear assembly to get a tighter mesh. This has to be done on the RC8 with the kyosho spur because of physical differences between the kyosho spur and the AE spur. You could just try adding shims to different areas and see what happens to the action of the diff. If you add shims and it doesn't bind up, the diff probably needed them. If instead you add shims and the diff gets grindy or tends to bind then it probably didn't need them.
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
M18 Special Graphite Edition questions slaytanic Micro and Mini Scales 50 02-09-2009 08:55 PM
So, with 2008 now almost over, what would you like to see in r/c for 2009? tc3team Electric On-Road 80 12-24-2008 10:30 PM
TOO MUCH MOTOR?!? vnmsgt Nitro Off-Road 25 11-04-2008 12:43 AM
