Old 12-31-2008, 01:00 AM   #16
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Originally Posted by Duster_360 View Post
+3 on the Hakko, but I'll still use my 80watt Weller for building pacs.
Tricks - tin everything, use good solder (I use Deans solder only), make sure solder is melted on both pieces when making a joint.
what do u mean by "tin everything?"
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 12-31-2008, 05:36 AM   #17
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
http://www.hmcelectronics.com/cgi-bi...ery=tip+tinner
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 12-31-2008, 05:42 AM   #18
Hide's Avatar
Lrp Station. I love mine.
Losi 8ight-E 2.0, LRP Shark, Xray M18T custom extended, Traxxas VXL Revo
Hide is offline   Reply With Quote
Old 12-31-2008, 06:39 AM   #19
Regional Moderator
CarbonJoe's Avatar
Okay guys, i just came from nitro 1/8th scale offroad to electric 1/8th scale and 1/10th scale. all of a sudden, wala.... i have about 12 batteries to manage, mostly lipo and few nicads. I am finding my soldering iron is not melting the solder deep enough to bind with the metals and wires. What's a good soldering iron and what are the tricks of good soldering!!!
thx!!
Soldering tips here: http://www.rctech.net/forum/5225617-post76.html
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 12-31-2008, 11:52 AM   #20
Trader Rating: 21 (100%+)
In soldering, you're usually joining 2 pieces. I mean tin both pieces - heat each piece and melt solder onto/into it. Set aside and do the other piece. Wait for last piece to cool. Now, when you put them together, the solder is already there - just heat both pieces together and melt all the solder. No need to try find a 3rd hand to hold solder and melt/feed it into the joint.
Duster_360 is offline   Reply With Quote
Old 01-09-2009, 01:54 PM   #21
teeforb's Avatar
Im back. I have a question on the hakko 936. which solder iron size do you guys use? small, medium, or large. on amain, the sell nothing but the large. so im assuming that's the way to go. at fry's, they have the medium iron. Does the iron size really matter?
thx
Old 01-09-2009, 01:58 PM   #22
Ordering a soldering clamp as well, it makes life so much easier!
Old 01-09-2009, 01:58 PM   #23
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by yodace View Post
936 hakko iron or the new Lrp iron are nice... the lrp has a digital read out...
I agree. Id like to get a LRP station though, looks pretty nice!
Originally Posted by abailey21 View Post
Hakko 936, you'll never need another one
Yup!
You think its nicer then the Hakko? Id like to get one and compare them.
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 01-09-2009, 02:03 PM   #24
teeforb's Avatar
where can i get one of those?
Old 01-09-2009, 02:05 PM   #25
Ebay or a hobby shop. They're like $10... Search for soldering clamp.
Old 01-09-2009, 02:13 PM   #26
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Weller SP40L ~ 13 bucks and going on 2years !!!
Hakko's nice i have used them but how much soldering you gonna do ? alot then get the hakko.
alil... get the weller.
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 01-09-2009, 02:21 PM   #27
Super Moderator
A good iron, and tinning the tip are cool. But if you want to do it right, make good joints quickly, then add some flux after tinning and before putting the connection together. The joint will be established much quicker and stronger. Quicker also means less heat damage to the battery. For batteries it never hurts to scuff the surface some first as well.
Dave H is offline   Reply With Quote
Old 01-09-2009, 02:48 PM   #28
DARKWAV's Avatar
Tinning each connection before joining works well for me, so does a chisel tip on the iron. A someone mentioned earlier sometime you can just heat up the pre-tinned pieces and the solder that is already on there will just flow together when heat is applied for the join...but still sometimes like when soldering 12 gauge wire to a deans it still seems like it can take awhile to get everthing heated up enought to melt the solder. Tinning the tip of the iron helps with that heat transfer, that small bit of melted solder on the iron heats up the joint pretty fast quickly melting the solder that is already on the connections as well as the extras solder you are adding to the joint from the spool.
Next time I have a solder job I'm going to try out some flux. I didn't think I would be doing much soldering at first so I was hesitant to buy a bunch of stuff, but it is worth making the investment to make the operation as easy as possible.
DARKWAV is offline   Reply With Quote
Old 01-09-2009, 03:07 PM   #29
teeforb's Avatar
is tinning some solution to buy? exactly what is tinning?
i have located a hakko 936 at hobby people with blue skins for $85. i will be on my way to pick it up!!!
Old 01-09-2009, 03:19 PM   #30
Trader Rating: 46 (98%+)
Hakko for sure. Flux Flux Flux Flux you will be mad that you never used it before.
Losi 8ight 2.0 sirio evoIII
Losi 8ight T 2.0 .21 vpec-t
Associated SC8
Jammin Crt.5 .12 Picco
everyjuangohome is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 11:20 PM
Weller 100watt Soldering Iron burnineyes R/C Items: For Sale/Trade 9 08-11-2009 03:06 PM
Best soldering iron???? racer1812 Radio and Electronics 30 01-30-2009 04:46 AM
i cant solder, help please nitro stan Electric Off-Road 80 12-31-2008 07:00 PM
Busted my soldering iron... goot irons any good? JusBox Electric On-Road 71 02-23-2007 09:18 AM
Soldering ESC - need help jgroenhof Electric Off-Road 9 01-18-2007 11:38 AM
Cold Heat Soldering Iron? axel Electric On-Road 17 03-31-2005 11:58 AM
