Old 12-31-2008, 09:07 AM   #16
Dorion's Avatar
Thanks for all the input. I'll definately look into the suggestions, but one more question: Do I need to worry about how much I discharge the Nimh batteries or can I take them all the way down?
Thanks!
Dorion is offline   Reply With Quote
Old 12-31-2008, 09:14 AM   #17
d4man's Avatar
Thanks!
The discharger I recommended will take it down to 5.4 volts....These bulb dischargers take it down to zero (unless there is a voltage cutoff) -- not good
d4man is offline   Reply With Quote
Old 12-31-2008, 09:15 AM   #18
ChrisWolfson's Avatar
Send a message via AIM to ChrisWolfson Send a message via Yahoo to ChrisWolfson Send a message via Skype™ to ChrisWolfson
All are good suggestions...
D4man knows his stuff with batteries. I'm sure his discharge device works great. Here's some input from me as to what I use for my nimh packs since I'm one of the last guys still running them at my track.
Say I just finish a heat. I put the battery away for the day just as I take it out of the car.
When I come back the next race day, the first thing I do is discharge the entire pack down to 5.4 using my Orion Advantage charger.
http://www.teamorion.com/Products/Ad...vanced+Charger
I've had the battery discussion with many people and most seem to think a discharge tray isn't necessary for 1/10 scale offroad. It's mostly for on-road I'm told. I have one and use it periodically. I've noticed when I'm down on run-time on old packs if I cycle them and put them in my Tekin Battery Doctor they tend to come back with better runtime. If you're utilizing this, after you discharge the battery on the charger, you would then put the pack in this tray until all the lights go out. Then let the battery cool if it's warm, and recharge the battery at about 5 amps.
http://www.teamtekin.com/dischargers.html
Hope all this helps. You can substitute the light bulb strands shown above for the charger if need be.
Happy racing!
TLR / Horizon Hobby / Spektrum / Tekin / JConcepts / MIP / B-Fast RC / UpGrade RC
ChrisWolfson is offline   Reply With Quote
Old 12-31-2008, 09:35 AM   #19
What I do is after I heat I discharge it on the Integy 30 amp discharger (as d4man already said) then put it on a Novak Smart Tray to balance it out. At the end of the race or when I have some time I charge it for a couple minutes so it doesnt go under .9 volts per cell.
I have a digital multimeter and it shows each cell at 1.3 or 1.2 volts discharged. So when all the lights on the Smart Tray went out, there was still 6.5-7 volts in the battery. Why is this?
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 12-31-2008, 09:49 AM   #20
Trader Rating: 19 (100%+)
I was told to race the nimh batteries. Then after that race,just put the batteries away.
I discharge the batteries at the track a week later, and then charge them back up.
I use a Duratrax 20 AMP discharger and Novak smart tray.
Speed Passion-B-Fast R/C-Liverc.com-Dirt Heaven-Revolution Raceway-Venom Designs-M&M Home repair and remodeling LLC-92 Zero Designs.
b4wires is offline   Reply With Quote
Old 12-31-2008, 10:05 AM   #21
jmcvicker's Avatar
Discharge trays may not work here - he says he has the Orion Rocket Packs which are stick-packs.
You may just want to peak-charge them once a month or so and let them slowly self-discharge. Or, look into one of those light-bar dischargers and just charge + discharge every few weeks.
jmcvicker is offline   Reply With Quote
Old 12-31-2008, 10:38 AM   #22
Dorion's Avatar
Again, thanks for all the great info. Do you guys think this will be sufficient for what I want to do? It seems cheap and it says it will only discharge the Nimh to 5.4. What do you all think?
http://www.amazon.com/Sweeper-Discha...0740389&sr=8-1
Old 12-31-2008, 10:51 AM   #23
d4man's Avatar
Hmmm, not familiar with that discharger. It might be a pulse type discharger, meaning that if its a 20 amp discharger, it discharges in short bursts or pulses. What does that mean?? It takes a long time to discharge the battery and the discharger doesn't get very hot.
Old 12-31-2008, 10:59 AM   #24
Dorion's Avatar
d4man, would the amount of time it takes to discharge make a differance? or do you think I would be fine with that kind of discharge? Sorry about all the questions, just trying to learn as much as I can.
Dorion
Old 12-31-2008, 11:00 AM   #25
d4man's Avatar
I put a multimeter on my Integy discharger and the battery and right after it discharged to 5.4, the voltage immediately jumped back up to around 7.2 volts. So I guess you'll have to discharge and go right to the novak smart tray....
Old 12-31-2008, 11:06 AM   #26
d4man's Avatar
Dorion
If you had a fully charged 4500 battery and tried to discharge it with a 20 amp discharger, it would take little bit longer then if you used a 30 amp discharger...
For me personally, at the time, I wanted to discharge my batteries to as close to racing conditions as possible...
Old 12-31-2008, 11:25 AM   #27
Dorion's Avatar
Ahh. I see. Again, thanks for your help d4man and everyone that chimed in. I ordered that charger from Amazon. For the good price it seemed to meet the objectives
discharging koolkidd Electric On-Road 25 06-08-2007 02:43 AM
Discharging batterys ? Anthrax Rookie Zone 6 05-23-2007 07:05 AM
