CVD's over dogbones
My B4RS came with dogbones, what advantages will CVD's have over dogbones if i get a set?
CvD`s offer better forward traction
Dog bones offer more side traction |
Wild Cherry, can you explain the theory behind why that is?
How does the style of axle change the forward and side traction levels? |
Dog bone bind less when rotating though the turn , delivering more side traction ..
The same play between the bones and drive axles produces less forward bite.... also dog bones rotate smoother with on-power steering, less hook than a CvD... This due to when a CVd spins it tries to straighten out or go flat and straight. That can make the car hook on power when turning and accelerating.. |
So, there are actually advantages to having dogbones as opposed to CVD's? I thought CVD's were always the better all-around choice.
not like one is better than the other , just another tuning option ...
Originally Posted by Wild Cherry
(Post 5221456)
The same play between the bones and drive axles produces less forward bite.... also dog bones rotate smoother with on-power steering, less hook than a CvD... This due to when a CVd spins it tries to straighten out or go flat and straight. That can make the car hook on power when turning and accelerating.. Good info WC. |
Cvd's also keep you from searching the track when you pop a ball cup:sweat:
i always liked the feel of cvds over bones.. but i did run bones a few times
