Old 12-24-2008, 07:48 PM   #1
Default XL-5 Stampede ESC weird issue
Hey guys, I just bought an XL-5 ESC to replace my old XL-1 ESC and I set it up and it runs great. The issue I have is that every 4th or 5th time I turn it on and I hit forward the car goes in reverse and when I hit reverse it goes forward. Then I have to put it in programming mode and reset the throttle and reverse and then it works for a couple more times. Im not sure whats up.
Also, I'm heading to the LHS to buy a battery the day after Christmas - I have the XL-5 ESC and a Trinity Speed Gems 17t Pro Amber in a Stampede. I have a 15t pinion - I need to know if I should go 7cell or 8cell. Traxxas.com says I can go 8cell but I don't want to heat anything up too much...I was the most power I can get without breaking the car...I can switch the spur out to make the 8cell more realistic so im not just flipping the car all the time doing wheelies...as of now with a 7cell 5000mAh venom battery from another one of my cars it wheel stands with full throttle assuming it has traction...any recommendations?
quickshot23 is offline   Reply With Quote
Old 12-24-2008, 08:02 PM   #2
StampedinIT's Avatar
Send a message via AIM to StampedinIT
have upgraded your tranny yet? if not you may want to look into the vxl tranny gears before running and 8 cell but you should be fine otherwise
StampedinIT is offline   Reply With Quote
Old 12-24-2008, 08:44 PM   #3
Default trans...
thank you for the advice...im gonna do that asap but atm the money has to go for the battery...any ideas on the ESC issue?
Old 12-27-2008, 12:25 AM   #4
Default ESC issue anyone?
anyone have any insight on the ESC issue above - and also an update on the battery - I chose a 8.4v 4600mAh hump pack due to some advice from my lhs guys...but the ESC issue still stands...anyone?
Old 12-27-2008, 10:01 AM   #5
Trader Rating: 52 (100%+)
i would call traxxas they have great customer support.
wheelie boy is offline   Reply With Quote
Old 01-01-2009, 03:56 AM   #6
If you want 8 cell go for it. I got a stock stampede (with a ton of replacement parts) and it flys on an 8 cell, does wheelie stands and flips itself over with some traction. Is it just me or does traxxas go thru parts like no other
Mud4Life is offline   Reply With Quote
Old 01-01-2009, 07:41 PM   #7
Default Brushless...
well I chose to go brushless with it - we are getting a mamba sidewinder or a mamba max - not sure yet - any insight on what the advantages of the max over the sidewinder are?
Thanks guys
Old 01-01-2009, 07:55 PM   #8
rcnate's Avatar
Send a message via MSN to rcnate
The sidewinder is a better update to mamba.
2 E-Maxx's
Team Associated RC 18T
Team Associated RC10 T3
DuraTrax Evader
rcnate is offline   Reply With Quote
Old 01-01-2009, 09:31 PM   #9
Default ?
Im not sure what you mean by update? isnt the mamba max a higher esc?
Old 01-01-2009, 10:23 PM   #10
Send a message via AIM to sexystover
personally i would just scan the for sale forum and pick up a used brushless setup to save sme cash
sexystover is offline   Reply With Quote
Old 01-02-2009, 12:08 AM   #11
Default used...
Used vs new in a brushless setup - what things could be bad with a used setup - like with brushed motors most likely I would have to swap out the brushes and springs but for brushless is their anything like that I would have to worry about?
Old 01-02-2009, 06:36 AM   #12
im new to brushless but from my understanding as long as the setup has heat protection (shuts off when it gets to hot) yoou really cant damage them other than physical damage you can cause by scratchiing/denting etc, or getting the esc wet
Old 01-03-2009, 02:04 AM   #13
Default HPI...
I saw this video for the Savage Flux brushless and it looks sick...would that system be a better system then the mamba max or mamba sidewinder for the stampede?
