Old 12-24-2008, 09:01 AM   #1
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Default quick 1/10 4wd setup question
hi,
i have a few questions. i have a b44 with a mamba max 5700 setup.
1) what pinion should i go with?
2) should i use sway bars or not?
3) what's the best all around tires?
i tried the b44 forum, but no answers on most of my questions. i would like to go to the LHS soon to see if i can buy today.
thx
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 12-24-2008, 09:16 AM   #2
markus216's Avatar
Send a message via AIM to markus216
Hello
What pinion you use depends on what spur gear your running. A gearchart goes for any motor as long as you know your spur and pinion. www.gearchart.com Just go there and find your car. It should say your Internal Resistance, aka Transmission Ratio. Now the key to gearing is the lower the number Is a higher gear. The Higher number the the more torque or bottom end. You want somewhere in the middle, where your motor temp isnt too hot and feels nice and fast. As for sway bars, you use them depended on how the cars handling. A sway bar's main use is to minimize the side to side movement, therefore increasing overall traction depepnded upon where you put them.Im not an offroad guy so Id suggest asking the local guys or If you have no local guys and just have fun runnning is around alone, EXPERIMENT.
good luck
-Markus Scott
Xray M18 Pro, CRC 3.2R
(MRL)Micro Racing League - www.microracingleague.com
markus216 is offline   Reply With Quote
Old 12-24-2008, 09:19 AM   #3
teeforb's Avatar
they don't seem to have the B44. :0(
Old 12-24-2008, 09:36 AM   #4
gndprx's Avatar
Trader Rating: 18 (100%+)
Is this for racing?
The best option is to always talk to the guys at your local track. Tire choice especially varies from track to track, so just ask the ones who know best
Carl Fisher
Team Xtreme RC
The Grove Racing Center
gndprx is offline   Reply With Quote
Old 12-24-2008, 09:39 AM   #5
teeforb's Avatar
i will be running at a 1/8th scale track. hardly any 1/10th scales there. it will be hard to find someone else with a b44. im just looking for a general setup, an all around setup.
Old 12-24-2008, 10:02 AM   #6
MikeDeadly's Avatar
Location: San Marcos/San Antonio, Tx but chillin in Orlando, FL for now.
Send a message via AIM to MikeDeadly
http://www.teamassociated.com/racerh...setups_b44.htm
Apply as needed....
Wash, Rinse, Repeat....
For external use only....
MikeDeadly is offline   Reply With Quote
Old 12-24-2008, 10:24 AM   #7
teeforb's Avatar
thanks!!! good enough!!!
Old 12-24-2008, 02:18 PM   #8
teeforb's Avatar
one more quick question.
are the b44 rear tires and wheels the same as the b4 rear tires and wheels?
Old 12-24-2008, 02:22 PM   #9
yes.
Chris Brown is offline   Reply With Quote
Old 12-24-2008, 02:27 PM   #10
teeforb's Avatar
thanks!!!
Old 12-24-2008, 03:41 PM   #11
teeforb's Avatar
another question... sorry... b44 is standard 48 pitch gears, right?
Old 12-24-2008, 03:59 PM   #12
Trader Rating: 20 (100%+)
yes
215slowpoke is offline   Reply With Quote
