Old 12-23-2008, 11:30 PM   #1
Send a message via AIM to sszzxx
Default gearing 17.5 in losi xxx-cr
How do you guys gear your 17.5 brushless motors in a losi xxx-cr i have a novak brushless 17.5 and was wondering how i should gear it. Around what kind of ratio should i have etc....
sszzxx is offline   Reply With Quote
Old 12-24-2008, 12:06 AM   #2
andrew-01's Avatar
Trader Rating: 22 (100%+)
http://www.rctech.net/forum/electric...very-soon.html
ANDRXW.com
andrew-01 is offline   Reply With Quote
Old 12-24-2008, 12:09 AM   #3
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Default XXXCR gearing
I am running 70/34, this is with a LRP 17.5 motor
The 70T is from my Schumacher Mi3 on road car and I have made a insert for it to fit on the shaft.
There is 2 new spur gears for the B4, 72 & 75, should be in the stores soon, using the B4 slipper pads this will fit the CR.
Regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 12-24-2008, 05:44 AM   #4
sounds like i need to order a special type of 70t spur so that it wont screw up the input shaft ? or am i confusing myself
Old 12-24-2008, 08:12 AM   #5
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
very interesting, missed this 1
r
UltegraSTI is offline   Reply With Quote
Old 12-24-2008, 01:19 PM   #6
mini-t12's Avatar
Default gearing issues
i run on a larger track.. ex pegasus hobbies and i run a novak 17.5 wit lipo and i gear 35/76 for smaller tracks 33 or 34 pinion
mini-t12 is offline   Reply With Quote
Old 12-24-2008, 01:28 PM   #7
I have a question it seems like you have to go through some trouble to get a 70t spur on with like a 35ish pinion. Why cant you just put bigger gears to get the same ratio like run 80t spur 39t pinion to basically get the same 5.001 as the 70t spur 34t pinion ?????? seems like youd be saving yourself the trouble of having to buy that adapter ?
Old 12-24-2008, 01:42 PM   #8
GSM Storm's Avatar
Thumbs up
You can't fit that big a pinion under the gear cover, when Associated release the 72 T spur, it will fit straight onto the losi, you just need to get the associated slipper pads as well.
May be losi will release a smaller spur gear soon.
Merry Christmas
Regards
Gary
Driver Gazza
Old 12-24-2008, 03:26 PM   #9
andrew-01's Avatar
With a trans ratio of 2.6 with 72/34 you will still be at 5.50 fdr. That is also with shaving the gear cover to accept a 34pinion. Now drop the 72 to about 65-66 with a 34pinion and your down to 4.97(65) or 5.04(66).
Check out the pinion and spurs at speedtech.
Pinion http://www.speedtechrc.com/store/ebcategory.asp?id=708
Spur
http://www.speedtechrc.com/store/ebp...?catmainid=392
ANDRXW.com
Old 12-24-2008, 09:12 PM   #10
Trader Rating: 198 (100%+)
Originally Posted by andrew-01 View Post
With a trans ratio of 2.6 with 72/34 you will still be at 5.05 fdr. That is also with shaving the gear cover to accept a 34pinion. Now drop the 72 to about 65-66 with a 34pinion and your down to 4.97(65) or 5.04(66).
Spur
Your math is off some a 72 spur with a 34 pinion is not a 5.05. It is a 5.5 FDR.
Gearchart.com may help you out some.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 12-24-2008, 10:10 PM   #11
andrew-01's Avatar
Accidentally read it wrong. I'll fix that thanks
ANDRXW.com
Old 12-25-2008, 04:08 AM   #12
so i can buy those spurs from speedtech and it will fit on my xxx-cr with like a 34 or w/e pinion i have ? and id be good to go ?
Old 12-25-2008, 04:36 PM   #13
scrawl's Avatar
I tried a lot of pinion/spur combinations and ended up at 35/69 (4.79 FDR) with an Xcelorin 17.5. Timing on the ESC is set around 11 degrees. Temps are around 138F after a 5 minute run.
Largest pinion I tried was a 37 pinion. It fitted without shaving the gear cover.
The turbo hub will fit on your XXX-CR (be sure to buy the Losi/Ass one, not the Kyosho version). With a 65 spur, the smallest size pinion that will fit is 33. A spur gear around 68-70 will get you into the ball-park.
stivesrc.org.au
"It's a spending hobby. You race occasionally."
scrawl is offline   Reply With Quote
Old 12-25-2008, 06:54 PM   #14
lol how about 27turn brush stock motors ? i got some custom built 27 turn and i never really race offroad how did u guys used to gear 27t's ? i think i have a 20t pinion in there with the stock 78t spur is that good ?
Old 12-25-2008, 08:58 PM   #15
scrawl's Avatar
23-24t pinion with a 78t spur for me. This is with a EA C027.
stivesrc.org.au
RC10B4/T4 Forum DerekL Electric Off-Road 14339 12-13-2017 11:20 PM
XXX-NT AD2 Thread DemonLosi Nitro Off-Road 2247 12-13-2017 06:30 PM
T.R.C.R. ---Pit's Talk--- teambighead Northwest Racers 25141 12-03-2017 10:06 AM
Losi xxx-4 Chrissy C Electric Off-Road 2902 05-26-2011 10:10 AM
Family Hobbies On & Off Road Racing In San Diego Jon Kerr Racing Forum 10726 09-11-2009 11:29 AM
Ups For XXX-T kjkiller Electric Off-Road 32 07-19-2006 12:13 PM
