Tekin RX8 1/8 Scale Brushless ESC Thread
#3826
We've been having trouble with the server being really really sloooooooow or just not loading at all. I'm working on it as it lets me
#3828
DJ
æ
#3830
#3831
side note: the sensored system is just awesome. being able to just creep around then just nut it and over jump a triple is incredible!!!
In a 6 minute qual. i was 13 seconds faster with the ebuggy than my nitro buggy. 4 races on the nitro and 1st time out with the ebuggy. it just makes you smile on the stand.
#3832
Sorry Reaper I'm a lil late on this but I feel for you because I myself had way too many problems with the product so it's in the corner of the cubical here at Ofna and ordered and Castle product.
#3833
I must say I myself am dissappointed also as I just installed my RX8 in my Buggy and It has been determined by Tekin that I have a bad sensor in my motor.
The good news was they told me it is an easy fix. The bad news is they don't have the part in stock
Randy I originally spoke to you and I was leary of trying a new system with out seeing it first and you were going to find some team guys so I could check it out, I never received a reply, I guess no team guys in Tampa.
I gave it a shot anyway and right out of the box problems. I hope this system ends up being worth it seeing how it is almost $100 more than the Mamba with the Hot Wire.
#3834
#3835
Less then one minute into my "test run " (on LEVEL DIRT!NO JUMPS!)
My "revised" new rx8 esc stopped working
Servo works,no chirps,no fan on startup.
So to recap.... I have bought my 1st esc Early July and that one lasted about 5 minutes. That gives me about 6 minutes of total run time since early July.
I know what you all are thinking."He must be doing something wrong". Well I have been using a Castle esc (with the 2050) while the 1st one was out for repair with no problems (aside from broken fans). I also let a fellow racer (electronics repair person) solder this one (just to be sure I did not mess the last on up).
No luck....
I am going to try a reset with the hotwire and check all the wires but it don't look good.
I don't know what else to say... VERY mad right now.
BTW I had five other racers that were at track with me that can vouch as to what happened.Not sure why I feel the need to say that ,just do.
No luck....
#3836
It won't connect with the esc at all(hotwire). I did work before the test run.
What can I try next?
#3839
I'm thinking of getting the RX8 setup.
Advise would be appreciated.
I'm limited on space on my Z01B and moving the chassis brace/diff is not an option.
Would a 1550kv with 19t pinion work better or
1700kv with 17t pinion.
running 4S 5000mah. 95% of the time.
I don't want it to overheat. and smallest pinion I can fit on my car with tekin motor is 17t.
#3840
when you power it up from a battery do all the light flash or nothing at all
Faast rx and servo boot up.
No lights.
I don't get get it. Maybe they sent me someones to be serviced esc by mistake? There is no way this was a tested new one.
I have been in the hobby for 25 years and have never had bad luck like this. I used EVERY precaution on this one.No screws,gyro jelly pad,clean solder job,no jumping.I know how to treat my equipment. (sorry feel the need to say that too).I guess I am in a bit of shock about this all.
No lights.
