Tekin RX8 1/8 Scale Brushless ESC Thread
Same thing happened to mine, it started glitching and then just crapped out, wasn't running an external BEC though. Do you have the Hot Wire? Mine would still power up through the Hot Wire.
I sent mine in last week, it's already done and on it's way back home, in the mean time i bought another new RX8 / T8 system lol.. So now i have two complete systems..
ESC shutting down
Hello Guys,
I need some help in isolating an issue that I had tonight. I am running on an indoor track small to med size.
I do not know what to try out next>? I also installed a new sensor wire.
Thanks in advance.
- I am running a Tekno sct410 with an RX8 with the 4300 HD motor
- Geared with a 15 pinion
- tried different IP packs 7200 at 80C
Thanks in advance.
I have a similar problem and no solution
Loaded the new software in my RX8, smoother throttle and brakes, nice upgrade Tekin!!!
Do you have a trade in program for the RS, would like to try the gen II rs, even though my current one seems pretty good.
Hello Guys,
what radio and servo?
Thanks in advance.
Thanks in advance.
Ok, so dont know why i took a brand new in the package rx8 out of the package about a month ago, i put a castle bec pro on it cause im runnin hv servos, anyways it was glitching real bad today anyways it ended up not working any longer the esc shut off and wont turn on its getting sent in monday hopefully tekin will fix it for me not having good luck with eletric. Haha thanks for being a big help tekin i highly appreciate it.
@ last2man
You removed the red wire from the esc to the rx?
ok I'm resting an RX8...downloaded the new software (because the Hotwire program said to).
It shows 224 but still won't allow me to update my RX8 or change settings...
Plugged the car back in to just make a run without the setting changes....now it won't even let the ESC turn on. (but I get power to the servo and radio just no lights or anything on the ESC) If I plug it in, I keep getting the message to update my hotwire... any suggestions?
I'd guess to try to install the update again. Just a WAG.
Yes red wire was removed through a short servo extension to no damage rx wire
Yes and it was bogging out my fans so i switched to an external bec, i now have another rx8 on the truck and its working great!
Sending mine in monday
So my most recent replacment is now having issues kinda gettin tired of tekin, when i turn the esc on there is no arming itsjust on no beeps or anything but seems to work fine any suggestions?
Has anyone had issues with an rx8 and a flysky fsgt3b
A rx cap takes power spikes And radio interference and eliminates them.'
http://www.amainhobbies.com/product_...tage-Protector
