Gear Ratio's - Need some Math Help
Ok, so I am trying to figure out my final gear ratio and all those other gear ratios, so I can input them into my data logger...
Here is what I have so far. Spur Gear - 44T Pinion Gear - 13T For a Primary Drive Ratio: 3.38 Front / Rear Diff Ratio: 4.30 Final Drive Ratio: 14.53 This is in a RC8e... Stock front/rear diff gears. Does this look right? |
Looks right to me
You need to get ahold of Tonys screws, he has a sweet gearing calculator that will do everything you need.
how do you figure out gear ratio's???
divide the big number by the little number.
Originally Posted by badassrevo
(Post 5185903)
whats the big number and whats the little number? When you divide those two you get a decimal, what is that number?
Originally Posted by TNS Racing
(Post 5186043)
Spur / pinion = primary drive ratio front/rear diffs - Big gear / Little gear = Diff Ratio You take the Primary Drive Ratio * Diff Ratio = Final Drive Ratio So in my case... 44/13 = 3.38 F/R ratio = 4.30 Final Drive Ratio - 3.38 * 4.30 = 14.53 |
