Old 12-18-2008, 07:46 AM   #1
gndprx's Avatar
Trader Rating: 18 (100%+)
Default Estimated run-time Yeah 3200 on 13.5 super stock truck?
I know quite a few are running the Yeah 3200 in the stock class. What type of run-time are you getting out of these packs?
Would it potentially make an 7 or 8-min main on a smaller track with a lot of throttle manipulation (not wide open the whole race)?
Carl Fisher
Team Xtreme RC
The Grove Racing Center
gndprx is offline   Reply With Quote
Old 12-18-2008, 07:50 AM   #2
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by gndprx View Post
I know quite a few are running the 3200 in the stock class. What type of run-time are you getting out of these packs?
You should make 7 or 8 minutes fairly easily with that setup. WHat I would do to be safe is to run 5 minutes and then check your packs voltage just to see how close you are getting to 6 volts. If your only at 7.3 or so you will easily make the 7 or 8 minute time frame.
ST Racing Concepts (STRC)
Old 12-18-2008, 07:54 AM   #3
gndprx's Avatar
I don't have one at the moment to do that. I don't want to buy the 3200 unless I can get a warm fuzzy about the runtime others are getting with a 13.5 truck.
Carl Fisher
Team Xtreme RC
Old 12-18-2008, 08:47 AM   #4
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
In a 5 minute heat/main I am only using 1000- 1100 mah depending on driving conditions. If i am just practicing I get around 15 min. till my li-po cut-off trips @6.5v. the 3200's are labeled correctly because if I run to the cutoff the pack will take 3200+ mah of charge.after a 5 minute main my 3200's all still read around 7.2-7.35v
*Vandal 4wd Late model*XXX-T sprinter*Micro scale specialties 1/24 'rock monster' crawler*MSS Micro-Rail*MSS Micro-Funny*MSS Micro-Outlaw*
2wdMod is offline   Reply With Quote
Old 12-18-2008, 08:58 AM   #5
gndprx's Avatar
Perfect, that's what I needed to know.
Thanks!
Carl Fisher
Team Xtreme RC
