Old 12-18-2008, 07:25 PM   #16
Trader Rating: 15 (100%+)
Default Newer lipos
Some of the newer lipos "Orion, Fantom....) you can charge at twice the amps, so keep that in mind when purchasing lipos. They charge really fast!
uncle everett is offline   Reply With Quote
Old 12-18-2008, 08:03 PM   #17
abailey21's Avatar
Trader Rating: 36 (100%+)
You sure about that?
At 1C a 5000Mah Lipo took me exactly 22 min 43 seconds to hit 8.4V
At 2C that same 5000 Mah LiPo took 22 minutes 27 seconds to hit 8.4V
Remember, the ramp down from 8.4 is the same no matter what charger you use so you can even add that to the equation.
I urge you to try it, the only thing you gain by 2C charging is 25% less life expectancy of your LiPo
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 12-18-2008, 08:03 PM   #18
tdeal823's Avatar
Trader Rating: 30 (100%+)
if you already have a power supply get the DC one.
I have the DUO is the best charger I have ever owned
tdeal823 is offline   Reply With Quote
Old 12-18-2008, 08:04 PM   #19
abailey21's Avatar
K.C.C.O.
Old 12-18-2008, 09:19 PM   #20
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
I recommend the higher output Hyperion 610 (250W) if you're running lipo. The 50w just won't have enough punch for a quick a charge. DC chargers w/ an external DC power supply are the way to go, the rating for built in AC/DC chargers is too low.
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 12-19-2008, 04:59 AM   #21
Trader Rating: 21 (100%+)
Originally Posted by Bump View Post
when i connect my (Venom 3600) NiMh battery to my new EOS0606i charger, i get to the charge screen and it reads like 8.xxx volts.
This is what I am doing..
plug in battery
plug into wall (no balance plug connected)
once its on i go to the nimh screen
choose 3 amps
hold down enter to start the charge and it started at 7.4xx and goes up
does it not cut off when full? or am i looking at it wrong? 7.2v venom 3600
Try turning the charger on, do your battery setup, then plug the batt in and start the charge. I think there is a option in setup for turning the end of charge alarm off, make sure thats not turned off. I know with mine, the alarm sounds for only 15sec or so and if you're not there, you might not be aware that the charger has signaled its finished.
Duster_360 is offline   Reply With Quote
Old 12-21-2008, 01:05 PM   #22
when disharging with the 0606i ac/dc, how do you go about a nimh 3600 battery? i wanted to discharge it, so i could recharge later this afternoon for a little run time before the work week. how many amps should i go for? its from .1 to 1 amp. the screen is like:
NiMH DISCHARGE
D=1.00A 4.8V
Bump is offline   Reply With Quote
Old 12-21-2008, 01:53 PM   #23
jmcvicker's Avatar
1A discharge, for sure. I discharge using an Integy charger at 4A - your discharge rate there is pretty slow (low). To discharge a 3000 pack if fully charged would take 3-hours. Why not just re-charge without a discharge? Should be fine for what you're describing.
It will always be above 7.2v when charging. I just did an enerG 4600mAh pack and it was as high as 9.7v when charging. It "peak detects" when full. So, when it senses a drop in voltage based on the peak method it uses, it will stop charging. If the batteries are *NOT* warm when fully charged, it could be a false peak and you should just hit "charge" again and let it keep going. It should peak when done and the batteries somewhat warm.
Discharging a sport-pack, like a Venom 3600 isn't really needed. Cell balancing is more appropriate but it's hard to balance a stick-pack, so the most appropriate way to handle a sport pack is charge to warm - then run a while. When the car starts to noticeably slow-down, stop driving. Let the pack "cool" a few hours and re-charge again fully.
jmcvicker is offline   Reply With Quote
Old 12-21-2008, 02:03 PM   #24
awesome, just wanted to know the proper way to handle this pack. thinking about using it in a mini slyder or slash. save lipos for the offroad truck.
Old 12-24-2008, 11:35 AM   #25
can u charge lipo on the eos0606i ac/dc without using the balance plug? it says its recommended but I have heard people dont balance every charge. do i just let it keep going once my "balance plug not connected" screen pops up?
Old 12-24-2008, 12:17 PM   #26
it doesn't say anything at all about NOT being safe....so we will see.
Old 12-24-2008, 02:42 PM   #27
air8's Avatar
You will be fine as long as your battery is currently in good shape. And assuming you don't draw the battery down below 6.4V. It's good to balance the batteries now and then. But when you get a balancer why not use it every time? Doesn't hurt.
I don't balance my batteries every time. But I'm about due for some new ones. I think I'm approaching or over that 300 cycles mark.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 12-24-2008, 06:28 PM   #28
Before I added balance taps to the 5S1P ands 6S1P a123 pacs I built, I obviously charged them without balancing using my 0610iNet. I did that for about a month til I finally added a balance tap to the pacs.
Old 12-24-2008, 08:53 PM   #29
dangerwr's Avatar
My understanding is that they recommend to balance every charge for packs 4S and above on the Hyperion charger. Before I did my 1/8th conversion with 4S I used 2S LiPo's on both my 1/10ths. I balanced once out of every 10 charges and never had any problems. I used Kokam cells which are believed to be top notch. Eventually I would balance every other time but noticed no difference. I hope this helps. Cheers!
Losi 8ight 2.0 EP - MMM & Tekin 1900Kv
Losi 8ight-T 2.0 EP - MMM & Tekin 1550Kv
Durango DEX410 - Orion R10 Pro & 8.5T
TLR 22 - Orion R10 Pro & 13.5T
dangerwr is offline   Reply With Quote
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Info on Turnigy Accucel 6 Crash74 Radio and Electronics 266 02-24-2017 07:34 PM
Hyperion EOS0610i Reg & Duo Lipo Chargers Still Bill Radio and Electronics 393 02-22-2015 09:39 AM
Hyperion, Novak, chargers, balancer, power supply fullsyzz R/C Items: For Sale/Trade 14 07-22-2009 05:58 PM
Ordering a new charger what to get. C_Money Radio and Electronics 19 05-26-2009 04:17 PM
