Old 12-17-2008, 08:07 PM   #16
action135's Avatar
bake them at 350 for about 10-15 minutes.
i've done this with several tires.
just put them on a pizza pan. bakes the tires right off.
you can reuse the rims again though, if any glue is left just peel it off or crack it off. loads faster than that acetone crap.
Ashton Brewer
First Bank & Trust Murphysboro
Alpha R/c Raceway
action135 is offline   Reply With Quote
Old 12-18-2008, 09:25 AM   #17
Suzukee's Avatar
So we can just slip the tires and rims into the oven, with no need for any form of cover? Will the oven be safe for food after that? Will aluminum foil help?
I mean, if baking or heating those rubber results in "fumes".
Suzukee is offline   Reply With Quote
Old 12-18-2008, 09:50 AM   #18
mkdut's Avatar
Trader Rating: 19 (100%+)
The baking method works great the first time. But after your wife smells the results you will be banned from doing this again. Better to get some acetone and put it in a 1 to 2 gallon bucket with a lid. Throw the tires in there over night and they should peel right off in the morning. Tires and rims can be reused. If you are not re-using the tires then cut as much of the tire off the rim as you can and then throw them in the acetone.
mkdut is offline   Reply With Quote
Old 12-18-2008, 09:53 AM   #19
d4man's Avatar
Yep +1
Dont forget Acetone is HIGHLY flammable. Not all tires can be reused, like Pink Taper Pins. Soaking those in Acetone will ruin them. Acetone will evaporate also....
d4man is offline   Reply With Quote
Old 12-18-2008, 10:32 AM   #20
action135's Avatar
the fumes really weren't that bad. i mean i even cooked a pizza later on that night
Ashton Brewer
Alpha R/c Raceway
Old 12-18-2008, 10:32 AM   #21
Tech Legend
Wild Cherry's Avatar
Tell me again how you just crack off the glue left over on the rim .
Its always gooie and a mess when its warm then cools rock solid hard & still glued on the rim after I pull the tire off ...
Wild Cherry is offline   Reply With Quote
Old 12-18-2008, 11:03 AM   #22
kvrc's Avatar
when ever i bake tires the left over glue on the rim just comes off by scraping the surface with an exacto. not much effort at all.
kvrc is offline   Reply With Quote
Old 12-18-2008, 11:05 AM   #23
What up?'s Avatar
Trader Rating: 14 (100%+)
Just started using the Acetone and its so easy and the rim comes out clean to be reused again.
Very easy.
Josh Mitchell
Speedtechrc.com / Team Orion USA / Airtronics / Proline / Bartalone Racing / rcinsider.com / 818Designs
What up? is offline   Reply With Quote
Old 12-18-2008, 11:40 AM   #24
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
acetone, forget boiling and baking. with acetone at worst u'll lose the foam (many of us thats what we're replacing anyway)
take an old tupperware/rubbermaid bowl (u wont eat from anymore) and lid. pour in 1/2inch or so of acetone. find a prop to keep ur tires above the acetone, u DO NOT need to immerse the wheel and tire, the fumes are what eats the CA. seal it up, go have a beer, watch the game, give the wife some attention and go to bed (u choose the order lol) and by morning (if not brunch), ur tires will fall off the rim and if either the tire or wheel will be reused, they will be fine to do so.
EASY?
R
UltegraSTI is offline   Reply With Quote
Old 12-18-2008, 01:13 PM   #25
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
EASY?
R
LOL isn't that what the second post says ???
anyways i am with you on that one pimp !!
I learned that from crazy carl, Go with ya badself !!
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 12-18-2008, 02:16 PM   #26
jnslprd's Avatar
i have a gallon of acetone in a sealed 5 gallon bucket that stays next to my pit space and just cut the tire off of the rim and throw it in the bucket .
Whenever i remember i check the bucket and its like christmas everytime.
The rims have sat in the acetone for 2 weeks and were fine,come out with no signs of glue anywhere. I hav probably done over 50 sets this way and it works flawless
jnslprd is offline   Reply With Quote
Old 12-18-2008, 02:20 PM   #27
johnnyboy's Avatar
Trader Rating: 28 (97%+)
Pretty much what I do. You can get a big jug of acetone at Home Depot for cheap.
Again though, acetone is NOT good if you want to re-use Losi Pink compound tires. Acetone shrinks them up like crazy!
"Almost Live Race Coverage": www.johnnyboy.ca
.:Team Orion : JConcepts : B-Fast RC:.
johnnyboy is offline   Reply With Quote
Old 12-18-2008, 03:17 PM   #28
el Bourlando's Avatar
I have had losi pinks expand in the oven, like balloons, if left in too long or too much heat! maybe you could counteract that with the acetone. lol
I have also cut the inner side wall and refoamed and reglued with success.
el Bourlando is offline   Reply With Quote
CRC Battle Axe, GenXPro 10, 1/10th pan, Brushless, Lipo,4c, Road, Oval,TipsandTricks John Stranahan Electric On-Road 1776 03-01-2016 01:18 PM
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 02:42 PM
