Slash - Replacement Parts diff from Stock??
I recently bent the rear stud axles on my Slash. After looking at the parts diagram, I purchased the replacements, part 2753X. After installing these parts, I noticed that the threaded part of the axle is much shorter and the wheel nuts barely screw on all the way. Has anyone else experienced this? I thought maybe I installed them wrong, but after comparing them side by side, I confirmed that the threaded area is much shorter.
Should I worry about this or just put some loctite on the threads before running? |
idk for sure but I was told the nitro rustler axels will fit:confused: it has to be a rusty not stampede. I'm getting my slash this week and plan on trying them out. I'll repost if they do
I think the ones you got in the kit were the improved, longer versions. Many were having trouble with the wheel nuts coming loose due to limited engagement of the lock nut. The longer axle helped this. My guess is the replacement parts of the older, shorter version need to run out before you will see the longer ones.
Matt, thanks for your reply, makes perfect sense. Should I apply loctite to be on the safe side when racing? These nuts only turn maybe three times and the locking part of the nut does not seem to engage at all. Very loose after breaking the initial seal. I'm almost tempted to put the bent ones back on.
Originally Posted by Matt Hawkins
(Post 5174388)
I always use loctite on mine. Never had one come loose after that.
I got around the issue by using a standard M4 nylock nut, the kind without the built in flange. They sit deeper and I havent had a wheel loss issue since changing over. Most hardware stores have them hanging in a bag for under a dollar.
