Losi Desert truck questions
I bought this DT while waiting on my Losi Comp Crawler to get here. Want to use it mainly around the house but also want to run it on my local indoor track. Want to do some initial setup to it to make it run a little faster and handle better. Here is what I have planned so far.
Change shock oil to heavier weight tune suspension to my liking change gear in rearend (small indoor course!) Question I have is, What upgrade to the electronics do I have to do to run Lipo or 7 pack NiMh batteries. The guy at the local shop said somthing about the overheat protection. Sorry for the newb question, just trying to figure a few things out before I tear into it. OH! I just realized last night once I got it home that the antenna on the radio was broken. Looks like I'm not having too much luck so far! :flaming: |
Originally Posted by jdubya
(Post 5172700)
Change shock oil to heavier weight tune suspension to my liking change gear in rearend (small indoor course!) Question I have is, What upgrade to the electronics do I have to do to run Lipo or 7 pack NiMh batteries. The guy at the local shop said somthing about the overheat protection. Sorry for the newb question, just trying to figure a few things out before I tear into it. OH! I just realized last night once I got it home that the antenna on the radio was broken. Looks like I'm not having too much luck so far! :flaming: Let me guess...the broken antenna looks like this....5 of 6 of mine were broken out of the box, just call Horizon and send it in for replacement: http://img03.picoodle.com/img/img03/...rm_60653bd.jpg On the Speed Control, your stuck with NiMh 6 cells for a while. Just save up and get a Havoc Brushless ESC\Motor Combo for the truck for 140-150....maybe a 13.5T or 10.5T MSC12RB 12T Fwd/Rev ESC Product Specifications Forward:Yes Reverse:Yes Time Delay Brake:Yes Input Voltage:4-cell (4.8 volts) to 6-cell (7.2 volts) DC Dimensions (WxLxH):1.25" x 1.02" x .888" Weight:1.2oz (34g) BEC Voltage:4.8 VDC, 1 amp max PWM Frequency:2 kHz Overload Protection:Thermal Full On Resistance:0.0014 ohms |
Wow, are you part of the phsycic friends network? Yes, that is exactly what happened to my radio. The main reason I bought it was because of the 2.4 system, but if it is this cheap, I might reconsider taking it back to get a slash.
(Post 5172773)
Originally Posted by y2kgtp
(Post 5172798)
Did you get it from A Main?
(Post 5172833)
Local shop.
(Post 5172855)
Maybe you can take it back? Or have them check their other stock.....5 of 6 of my radios were broken exactly the same way.
(Post 5172884)
I'm definately taking it back. I spent an hour in there trying to decide between the slash and the DT. I went with the DT because of the radio and the XXX-t platform on the DT. I know I can upgrade it to run on the local offroad track in the future. I spent all night last night comparing hop ups for both.
Slash can handle up to a 8 Cell NiMH battery for the ESC, and people also run 2 Cell LiPo's, I just don't think there is a cut off on the ESC, so will really have to watch it, or get a battery\cutoff system to kill it at 6V. The Desert truck is based off the XXX-T, but will require some $$$ to race in any of the track classes competitively. Most stadium truck is superstock (13.5T Brushless\LiPo) or Mod. You would need tires\rims for the track setup & a brushless ESC\Motor combo for the class you want to run. Then there are the batteries...... :lol: |
losi desert truck
well you dt comes as listed 16-tooth pinion / 88-tooth Spur..also the esc will not handle a 7.4v lipo. here is what and how I set peoples trucks up to run on the indoor offroad carpet track we run.. Get a Oracle 2esc by indi its a $40 investment nice spedo. abs and can and will handle a 11.1v lipo..Put a 90 or 92 tooth spur in it lots of punch good aceleration outa the corners..Best TnT I have also found the dt very glitchy with the 2.4 I think it is the rx-tx are cheaply made
Well, considering I will be putting 1200$ into my comp crawler, it looks like I will be keeping this one stock (yeah right!) for now. I can race this at the local indoor track and have some fun with it while I'm not crawling. It's kinda cheezy but I like the lights!!!!
I can do some small stuff to get a little more out of it. More than likely I will go brushless, but only after I get my crawler done. Thanks for the info! |
Originally Posted by tntpoof
(Post 5172924)
http://www.integy.com/cgi-bin/webc.c...556&p_catid=25 and says not to exceed 16T or higher, no more than 7 cells.....I would stick with a brand name that most people have heard of Like Losi Xcelorin, Novak, Tekin, LRP, etc..... Spektrum Rx\Tx are fine other than the packing\assembly issue noted above with the radio that Horizon takes care of for you no questions asked. |
