Old 12-15-2008, 04:31 PM   #1
Exclamation Problem with new Slash
I just got a new Slash and am having a problem with it. Keep in mind it is fresh stock out of the box with a Venom 3000 nimh battery. I charged the battery and installed it. Turned on the radio then turned on the truck but the light on the ESC goes red and nothing on the radio will control it. The wheels automatically turn to the right and sometimes will glitch around as soon as I turn on the truck. Any ideas what could be wrong before I call Traxxas?
Thanks!
TheGasman is offline   Reply With Quote
Old 12-15-2008, 04:32 PM   #2
Sounds like you need to program the esc.
StingerSkinz is offline   Reply With Quote
Old 12-15-2008, 04:36 PM   #3
R40Victim's Avatar
He should still have power to his receiver, and thus still have steering. I dunno, try taking it to your LHS and see if they can help you out. If not, pack it up and ship is back to Traxxas.
R40Victim is offline   Reply With Quote
Old 12-15-2008, 04:42 PM   #4
MackTuned44's Avatar
I run in to this problem quite frequently at are track with the Rentals (#8), like stinger said, try reprogramming the ESC, and make sure if you mess up the sequence upplugg the Battery. it make take a few try's but its very simple. with radio on, hold esc button till red blinks , then hold full throttle, wait for flash then press button, then go to reverse, press button, and let go...let it do its thing and you should be good to go....Kevin
Kevin
Jconcepts-Duratrax-TrakPower-MuchMore Racing
RCExcitement.com
MackTuned44 is offline   Reply With Quote
Old 12-15-2008, 04:59 PM   #5
Miller_Time's Avatar
Trader Rating: 11 (92%+)
Is it possible there is someone around you using a radio on the same channel? Also try checking the crystals on the transmitter and receiver, they might be loose.
www.HobbyStop.com
Miller_Time is offline   Reply With Quote
Old 12-15-2008, 05:19 PM   #6
Thanks for the replies guys!
I tried to do the reprogram of the ESC but it wont even go thru the steps. Shouldnt I at least be able to control the steering?
Ive checked the reciever and crystals and it all seems good. No chance of anyone being on the same frequency around here.
On a side note, when I turn the radio off but leave the truck on the wheels go back straight but as soon as I turn the radio back on the wheels turn right.
Im kinda at a loss.
Old 12-15-2008, 05:22 PM   #7
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
are the knobs on your radio centered, these are made by over seas maybe the hooked it up to the rx wrong.
roadrashracing is offline   Reply With Quote
Old 12-15-2008, 05:26 PM   #8
gashuffer's Avatar
Trader Rating: 48 (100%+)
Take it back and get a new one. Done.
T-Sal
gashuffer is offline   Reply With Quote
Old 12-15-2008, 06:31 PM   #9
offtraxx's Avatar
Trader Rating: 59 (100%+)
ur wire from the esc to the rx may be backwards, happend to me once. unplug the esc wire, turn the plug (three prong) 180*. if that don't work....+2 on the return it
I'm not a RC addict. addict's are in denial, I admit I have a problem
offtraxx is offline   Reply With Quote
Old 12-15-2008, 06:37 PM   #10
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
A possibility indeed. As a rule of thumb when looking at the receiver with the servos, ESC, etc. plugged in, the white wire(signal) should be closest to the crystal in the receiver. The black wire should be closest to the outer edgde of the case.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 12-15-2008, 06:37 PM   #11
Trader Rating: 21 (100%+)
+1, new out of the box, shouldn't be acting like this.
Duster_360 is offline   Reply With Quote
Old 12-15-2008, 07:38 PM   #12
I checked all that over and nothing seems to be out of place. I guess this is going back. Just hope they dont give me a hassle about it.
It figures just my luck! My first electric RC and already Im having problems.
Old 12-15-2008, 08:26 PM   #13
gashuffer's Avatar
Don't worry about it everything is going to be fine. These cars are put together in some assembly line and the assemblers don't know if the electronics work or not they just box them up and off they go. i'm sure you are not the first for this to happen to.
T-Sal
Old 12-15-2008, 09:07 PM   #14
Traxxas is very good about taking care of returns. I'd try your retailer first just to eliminate the waiting. If not, Traxxas will get you squared up.
www.HobbyStop.com
Old 12-15-2008, 09:08 PM   #15
I just thought of something else to check, someone mentioned the servo/esc wires being in backwards. Also check that they are not swapped - as in the esc plugged to the steering channel and the servo plugged in the throttle channel.
www.HobbyStop.com
Outdoor FREE Slash track in Seattle t0adman Northwest Racers 4229 09-07-2016 02:41 PM
West Coast R/C Raceway & Hobby Garage In So. Cali! DannyS California Racing 14045 01-19-2014 09:33 PM
Traxxas Slash spec class racing at Ryde in 2009 and beyond Roman Australian Racing 2293 02-20-2013 06:18 AM
SC10 Thread JDCrow Electric Off-Road 12123 05-29-2012 05:40 PM
New Traxxas Slash 1:10 Electric CORR Truck salteen Electric Off-Road 3949 03-19-2012 09:24 AM
Traxxas Slash -- Race Footage -- Video griz11 Electric Off-Road 51 07-24-2009 05:23 PM
Spur gear problem with slash Leroy1234p Electric Off-Road 17 06-17-2009 04:27 PM
