Old 12-14-2008, 04:33 AM   #1
Registered User
Default axle question
how do you take a trailing axle and make it an line axle. what size button head screw would i need. axle is 4 a b4
gvh82 is offline   Reply With Quote
Old 12-14-2008, 06:06 AM   #2
gregm's Avatar
Trader Rating: 57 (100%+)
Send a message via MSN to gregm
The trailing axle and the inline axle are 2 completely different parts.
Inline Axle (#6220)
Trailing Axle
If you want to run the Inline axles you will also need the compatible Steering Blocks (#6221). Good luck.
Racing makes heroin addiction seem like a vague wish for something salty - Peter Egan
gregm is offline   Reply With Quote
Old 12-14-2008, 05:09 PM   #3
Registered User
sorry center drilled so you use a screw to hold the wheel on not a nut
Old 12-14-2008, 05:18 PM   #4
schmelme's Avatar
I assume your talking about the blue aluminum factory team front axles they are center drilled for a 4-40 screw.
You can take the regular steel trailing axles and cut the threads off, drill and tap them for a 4-40 screw they will never break.
schmelme is offline   Reply With Quote
Old 12-14-2008, 08:54 PM   #5
skypilot's Avatar
Trader Rating: 14 (100%+)
inline means 'the axle is inline with the spindle'
trailing means 'the axle is behind the spindle'
and thus the need for a different carrier - (steering block)
semi retired..
skypilot is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 46185 Today 11:05 AM
Tamiya mini cooper sipaboy Electric On-Road 29687 12-10-2017 04:07 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Help with Droop please (David jun way) Wing Chun Australian Racing 8 03-31-2007 08:34 PM
