Old 12-12-2008, 09:35 PM   #1
Cheezburger's Avatar
Default Traxxas Slash range problem?
Hey all,
Just recently got the Traxxas Slash, and i seem to be having some range problems. I only get about 50-60ft before the car starts spazzing out. If i press full throttle it'll turn out of nowhere all the way in one direction. Is this a common problem? Thanks
Cheezburger is offline   Reply With Quote
Old 12-12-2008, 09:45 PM   #2
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
fresh batteries, antenna up?
roadrashracing is offline   Reply With Quote
Old 12-12-2008, 09:48 PM   #3
Yup, radio batteries are brand new and antenna is fully extended. The car battery is also fully charged
Old 12-13-2008, 03:30 AM   #4
SirSwiftAlot's Avatar
Location: SOCAL the fastest mini cooper guys in the nation
Did you put a personal transponder in it if so make sure its away from the reciever also check and make sure the crystals are properley seated in the remote and reciever and all the other stuff the guys said above me
Why do people park in a driveway but then drive in a parkway?
SirSwiftAlot is offline   Reply With Quote
Old 12-13-2008, 11:30 AM   #5
What's a transponder? lol. I don't think i have one. My current setup is: Castle Creations Sidewinder ESC + 4600kV motor, stock radio equipment, 3600mah Nimh battery. Nothing is near the receiver.
Old 12-13-2008, 12:25 PM   #6
offtraxx's Avatar
Trader Rating: 59 (100%+)
do u have the compasators on the sidewindor? little round dodads that should be on the backside or soldered into there own wires. I had the same problem with a novak setup, found one of the compasator wires hanging by a thread.
I'm not a RC addict. addict's are in denial, I admit I have a problem
offtraxx is offline   Reply With Quote
Old 12-13-2008, 02:44 PM   #7
Well all the wires on the ESC are are perfectly soldered on. The only other thing i see is the 2 capacitors but they're soldered on fine as well. I don't think it's the brushless system since i'm getting steering problems as well. After 60ft or so, when i hit the throttle it just turns to one direction out of nowhere. I also switched out the crystals on the transmitter and receiver from a good radio set but still the same problem. Maybe i just have a bad radio system? Hopefully Traxxas covers it under their warranty... I'm about to put the good radio system in and see if that helps.
Old 12-13-2008, 03:00 PM   #8
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
factory radio or after market, might have a bad receiver or crystal
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-13-2008, 03:15 PM   #9
It's the stock radio equipment. I just took the crystals from a good radio system. Same problem though. But yea i'm gonna put the Slash's radio equipment in my other car, since the other equipment doesn't fit into the Slash.
Old 12-13-2008, 03:26 PM   #10
scooter1985's Avatar
Send a message via Yahoo to scooter1985
I had the same problem..The turining of the wheels are the fail safe I guess...My batts where just dead though....Also check the waterproof rec. box, and see if the antenna wire is pinched...I have seen that before with all the wires...So check that..
scooter1985 is offline   Reply With Quote
Old 12-13-2008, 05:10 PM   #11
offtraxx's Avatar
are u running around high voltage power lines? my truck, b4 I fixed it, would only go 60ft at home and 150 ft at the track with no power lines near it
Old 12-13-2008, 05:49 PM   #12
Okay i just tried the Slash's radio equipment in my nitro car. And it works flawlessly. So now it's either the Brushless equipment or the servo. I'm going to check the servo right now. The wire was not pinched btw.
Old 12-13-2008, 08:57 PM   #13
Well i am near a baseball park with huge lights and some power lines. But it didn't affect my nitro car so i'm guessing they aren't the problem. I also tried braiding the brushless sytem's wires like someone suggested but that didn't work either... Well i don't know what else to do. Should i call Traxxas / Castle Creations? This has to be fixable since the Slash + Castle Creations combo is commonly used...
Old 12-15-2008, 01:03 PM   #14
So i called Castle Creations today. The only thing he could tell me was to braid the wires and try to move the ESC in different areas. Guess i'll do that tomorrow. I'll keep you guys updated.
Transitioning from nitro. What should my first car be? sokar Electric Off-Road 42 08-05-2009 08:12 PM
XL-5 + Titan 550 & Losi Micro Desert Truck **Free Shipping!!!** Cheezburger R/C Items: For Sale/Trade 7 12-14-2008 02:58 PM
