routing wires on xxxt-cr >
Old 12-11-2008, 01:52 PM
Default routing wires on xxxt-cr
I just got my losi motor/esc combo and everything is soldered. can anyone give me tips on how to route thing? do i have to remove anything from the esc and slide it through a certain area or what?
Bump is offline
Old 12-11-2008, 02:16 PM
INLINE V's Avatar
unsolder it.
http://images2.rdefined.com/v/Inline...40307.JPG.html
INLINE V is offline
Old 12-11-2008, 02:20 PM
thats not gunna happen not if I am doing it. figured they would make it easily installable being they are the same make and all.
Bump is offline
Old 12-11-2008, 02:27 PM
AZrcdriver's Avatar
You won't be able to get it thru the shock tower even if you try and take parts off.
You can run the wires on the outside of the shock tower and wire tie them to keep them out of the way.
Most people remove them and route inside the shock tower.
AZrcdriver is offline
Old 12-11-2008, 02:31 PM
i got em on the outside to clear the suspension movement and if someone at the track can do the soldering for me, i will then move them. thanks for the help guys.
Bump is offline
Old 12-11-2008, 03:44 PM
Trader Rating: 23 (100%+)
just take off the rear tirod and pop it back on
not home is offline
