Getting back into RC
I used to be pretty into RC cars. I have a traxxas E-maxx with novak brushless system that I got like 4 years ago, and the brushless i got about 2 years ago. The car is pretty screwed= the whole front end is jacked up, it barrely turns, the two front wheels are facing each other. On the Chassis, the antenna holder broke, so the antenna is just flopping around right now. And the shocks are screwed up. I was just gunna ask if anybody has any suggestions on what to do and how to fix it, because I was thinking of getting a gorilla MAXX racing suspension to fix the front end, but it was a little expensive, so im open to ideas on that. And I was also looking into getting some Road Rage tires and just a new plastic chassis for the car. Thanks for any advice.
well im just sort of wondering if there are any other options at all, since im not really up for dropping 500 bucks into the car right off the bat. The toe angle wont even adjust, ive tried to make them go appart all the way and it wont work.
Maybe you should just bring it in to your local hobby shop and have them give you some advice.....a brand new E-maxx is 349$ + shipping
http://www.amainhobbies.com/product_...ducts_id/20033
So you should be able to fix it for far less than that. Look on eBay for Emaxx parts:
http://shop.ebay.com/?_from=R40&_trk...All-Categories
Not sure how much the E-maxx has changed over four years, but I'm sure you can get spare parts to fix it without buying a new one.
E-Maxx documentation
Click that link. There you will find exploded views and the manual for the new E-Maxx. Most likely you can get it back in working condition for $50-60 unless you have some VERY major problems. That is the new version but I don't think many of the chassis items changed.
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 42 (100%+)
if your front end wont turn at all it sounds like the pivot balls are binding up. You might get lucky and be able to remove the pressure by loosening the pivot nuts that retain them and get it broke free . Hopefully the pivot balls arent all rusted to crap after sitting that long. As for shocks I just hapen to have the associated shock set for the maxx trucks laying in a box doing nothing Drop me a PM if you would like them I would part with them for cheap.
Because technically that's what they are designed after is a joint known as a pillow ball joint.
