what brushless systems can be mixed? >
Old 12-09-2008, 09:21 AM
AlanHall's Avatar
Trader Rating: 43 (100%+)
Default what brushless systems can be mixed?
ive got a novak 5.5 BL motor coming in a trade. do i have to use a novak esc with it or can i get a lrp that id rather have? but since im thinking about it . how do you mix and match set ups. i see alot of BL motors out from different manufactures.
AlanHall is offline
Old 12-09-2008, 09:23 AM
Trader Rating: 23 (100%+)
no problem at all. I see most onroaders use that. novak motor and lrp speedo. Works flawlessly. All i have to day is make sure you have the sensor wire hooked up first. They say the motor will heat up when its all hooked up if the sensor wire isn't on.
not home is offline
Old 12-09-2008, 10:38 AM
AlanHall's Avatar
Yeah i wasent sure if the plugs where the same and how well they worked together.
AlanHall is offline
Old 12-09-2008, 11:12 AM
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
anything that has sensored drive. b/c novaks are sensored. yes technically a castle can drive a sensored motor, but there are some hang ups. they are in fact working on a sensored speedo as we speak. and without question that is what i'll be buying upon its release
R
UltegraSTI is offline
Old 12-09-2008, 12:29 PM
RC Dad's Avatar
Trader Rating: 26 (100%+)
So is it safe to assume that all sensor leads are one standard size and number of pins? Totally interchangeable between brands and speedos?
RC Dad is offline
Old 12-09-2008, 01:59 PM
thats fine. novaks are a little different. they have the sensor wire built into the motor that goes directly into the speedo. i think all other motors have an easy pop out sensor wire. all leads and pins are the same.
not home is offline
Old 12-09-2008, 02:35 PM
porkey's Avatar
Get the LRP Sphere.
porkey is offline
Old 12-09-2008, 02:42 PM
Michael#81's Avatar
Trader Rating: 260 (100%+)
I would also recommend the LRP Sphere with either a Trinity based motor or a Novak motor.
I have had equally good luck wih both of those motors.
Michael#81 is offline
Old 12-09-2008, 03:49 PM
AlanHall's Avatar
thats what i was wondering
AlanHall is offline
Old 12-09-2008, 03:53 PM
Michael#81's Avatar
Yes all sensor wires should be the same pin placement and plug style.
I have ran 5 different motors and all of them had the same style sensor plug that went into the ESC.
